Just bought a pair of 201's with Trebax horns in a IB box. I intend to play about with them mounted on an open baffle plate.
In a room 14X9' firing down the room what size baffle should I use and where to mount the speakers (offset?). I'll use any suggestions as starting point to experiment.
I'm currently using Magneplanar MMg's with a valve amp and want to see what the fuss is about with full range speakers.
Any comments / suggestions are very welcome
Kev
Kev
This might interest you:
http://www.decdun.fsnet.co.uk/loudspeakers2.html
As an alternative experiment, I'd try a 4'x3' sheet of MDF to start with, the driver slightly offset from the centre (about 6" diagonal) as a start and see what gives. Try starting at 2 feet from the rear wall and work forwards.
So far as I'm aware, there's no decent OB modelling software, bar Martin King's MathCad sheet, which he hasn't completed yet, and probably won't release even when it is, thanks so some loathsome little tykes taking advantage of all his hard work just to line their own pockets. Pity; but I don't blame him (quite the reverse: I support his stance wholeheartedly).
Cheers
Scott
Cheers
Scott
The Edge
'there's no decent OB modelling software' - I don't agree,
try 'the Edge' (i'm sure someone here will have the link);
Pete McK
Pete McK
Nuuk said:
I assume you bought the 201's in the cabinets off Ebay UK this week Kevin?
Yes, picking them up this Saurday. I've seen your site and this and the Ciare250 thread were influencers in my decision to buy these. I noticed they are being used in a room much bigger than mine, hence the question about baffle size.
I was hoping to use smaller baffles than 4'X3' as this will completely dominate the end of my room being only 9'wide.
My amp will be rewired to triode mode from UL to reduce the power as the quoted sensitivity on these speakers is miles higher than on my current speakers.
THanks for the replies
Kev
Kev, you could go for smaller baffles but I think that you may find that you need a sub (or some EQ). 😉
I notice that your Goodmans share the baffle with a tweeter, what is it, where do you cross it over and what xover do you use?
I think I'll start with a copy of your baffle and experiment with wings. If I need a sub I'll do some research as your TL subs will simply be too big. Annoying in many respects but WAF is a major consideration, SWMBO is not understanding about these matters.
Kev
Kev
The tweeters come from CPC (can't remember the exact code) and are silk domes costing around a fiver each!
Even living here on my own, I find the TL's rather large. I went with them as I had the drivers but I would prefer OB subs given the choice.
The one advantage of the TL's is that you can build a couple and if SWMBO doesn't like them, you just say "Fine dear you can throw them out while I am at work" knowing full well that she won't even be able to lift one! 😉
I'm shocked no one's mentioned the JE Labs OB. Several people over on AA (ivan303 in particular, I think) have had great success with the 201 on this baffle.
JE Labs OB
JE Labs OB
True -I haven't tried that one myself I admit, though I know it, and thought about trying one out at some point: I've only dabbled with OBs so far.
My gut feeling is that with a baffle much smaller than 4'x3', you're going to need some serious eq due to the acoustic cancellation. I hope to be proved wrong though!
Well, a big part of the JE Labs OB appeal is that the floor-loading significantly helps out the low-end. Check out here. Brian Cherry of DIYHiFiSupply had his Fertins in a narrow, tall OB then moved them to the JE Labs OB -- night and day. I've used them with some completely inappropriate drivers, and they do extend the bass to some degree; won't knock any knick-knacks off of shelves, but I suspect that the Axiom 201s would do 40hz in those baffles.
Oh to have a decent hardwood in the UK... anyone know a good supplier? I'm lousy at veneering MDF.
- Full Range
- Goodmans 201's
