good tempest replacement?
My tempest in an Adire EBS alingment box went south on me and I need to replace it. FS=18.8 QTS=.38 VAS is 317L. Xmax is 16.4 mm. The tempest is no longer available, so what parameter is most critical for the closest match? Thanks in advance.
Actually this driver is already a warrenty replacement. The first was DOA and I waited two months to straighten that out, some two years ago. The other (I have two EBS tempests) has been problem free. I'm all set with adire and thier warrenty. The PE Dayton DVC-15 is the closest I could find to Tempest. I belive Eminence makes this Dayton as well as the Tempest. I was hoping for close enough to tempest but better quality if possible.
You're right these are not available...
So your best bet is the Dayton DVC or the Dayton Titanic...
Because of the lower Vas, the Titanic would have a small bump of 1 dB in-room between 15 and 20 Hz. It could take more power because it got more excursion.
Afterall, maybe you're better with the Dayton DVC, if the Titanic SQ isn't that much better.
