Anyone know where to find nice big but inexpensive heatsinks? Preferably, not used before... I've seen some other postings that show huge sinks...I'm looking for something on the order of 3 inches long (maybe even a bit less) and 6 inches wide. Thanks.
Doovieman
Doovieman
I've used these:
http://www.bgmicro.com/prodinfo.asp...6&prodid=ACS1395&page=1&cri=heat+sink&stype=3
I ordered 6 of them and they were unused, but about half of them had minor surface scratches on the ends. (You could see the bare aluminum, but no percievable amount of metal had been removed.
You can see them in action here:
http://members.shaw.ca/seangoesbonk/sgb3886.html
Edit: If you are interested in these, I can email you about half a dozen close-up photos of these.
Re: You call that big?
I beat you to it!
I used a pair of these in a LM3886 quad channel gainclone. (38wpc, 28Vdc rails) I use it with a pair of Tangband full-range fronts and a DVC Adire Shiva.
I was worried about the orientation of the fins, but it barely gets warm after a couple hours of use.
mercator said:The only problem is the fins run the wrong way for me.
I beat you to it!
hmmm...those are nice but I'm looking for something with the fins running the other direction and preferably silver. Any other suggestions? Thanks,
Doovieman
Doovieman
call it prejudism
but I like Steve from www.apexjr.com
and the stuff he has, he turns out more and faster than he can put on the websdite, that is why you should call him just in case.....
I have gotten some unbelievable deals from that place....
J-P.
J-P.
That apexjr is pretty hot. They're sinks aren't quite what I'm looking for but they're definitely a great resource...Thanks!! Any other suggestions for sinks?
You are in Berkeley, right? Check www.halted.com. If you havbe the time, the best bet is to drive to one of their shops. One is in Santa Clara( Lawrence Expressway and Central), one in Rohnert Park (just off 101 between Santa Rosa and Petaluma) and Sacramento.
No guarantees but there is a good chance you might find something.
Not on the website
Thanks guys for the good words.....
I have some small quantity's of used heat sinks
not listed on the website:
1st going to Doovieman if interested.
4 ea Aluminum 4 5/8" X 8" X 1 1/4 26 fins flat bottom $7.50ea
2 ea Black anodized aluminum 4" X 13" X 1 3/8 40 fins
also a flat bottom $10.00ea
5 ea Aluminum 7 1/2" X 10" X 1" 28 fins flat bottom $12.50ea
Steve @ Apex Jr
www.apexjr.com
Steve @ Apex Jr
www.apexjr.com
If Doovieman doesnt want the 2 black anodized sinks, I'm interested as I've been needing something along those very lines for the gainclones I'm building.
Steve, if he doesnt express interest, could you please email me?
Thanks,
Jonathan
Thanks,
Jonathan
Heatsinks
Doovieman is interested in the 4 5/8" X 8" heatsinks
leaving the black anodized available. Contact me
as I will hold them for you.
Steve @ Apex Jr
Steve @ Apex Jr
while we are talking heat sinks
Aavid Thermalloy has a Heat Sink Calculator on their website:
here's the URL:
http://www.aavidthermalloy.com/technical/thermal.shtml
here's the URL:
- Chip Amps
- Good inexpensive heatsink source?
