i found a 400w ballest,w pulb and it says it has a 10k bulb is that good or bad? and whats better 5k 10k 20k?
It's been awhile since i ran reef aquariums but i'm pretty sure 10K means it's more blue, which is bad, and the opposite spectrum of too yellow/red (below 5K)
you want pure while light so the colors are all true.........
5500 being perfect i think? so the ushio being 5200 or whatever is closest to white light. 7500 being acceptable as well? nothing above that though.
correct me if i'm wrong....
the higher the number, the more blue/purple..
that's why symbiotic zo0-algae that live in some corals and tropical mollusks are blue and purple, because they are sitting in water where the top of the ocean is getting UV light in the blue spectrum...
ok thank you that helps alot having a hard time finding a light sence i dont know a holelot about them and cheap as i can
any idea where i can get a bulb for this light or what kind to get. like what to look for.
http://cgi.ebay.com/400-watt-MH-Gro...ryZ42225QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
well, i'd like to know too since this is a real metal halide ballast and not the sodium one that you have to use the ushio conversion lamp which is what most of everyone here is using since it's only 28 dollars. (maybe this 48 dollar one is better since there are more lamps available)
Grotke would know but you posted this question on the wrong page, this should be on the "lighting" section when you look under the main "moving image" section.
could a moderator please move this too the Lighting section?
ok thank you sorry im on here every day and didnt see a lighting section.
you think this bulb will work
http://cgi.ebay.com/Ushio-400-watt-...ryZ42883QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
ok, the bulb you just posted is for a sodium metal hallide ballast like i was talking about... (it's only 28.00 for ballast from ebay vendor that is listed under "cheap halide ballast" thread in the Lighting section of our forum.
the ushio is 38.00 from atlantic which Grotke listed on the forum...
but i'm really not qualified to tell you which to get yet because when i had a reef aquarium, we only ran Electronic ballasts, while these two types are both magnetic and operate differently.
so i don't want to tell you which lamp or which magnetic ballast to get,
but please read this article right here, then you will know all that i know about these DIY halides....
http://www.diyaudio.com/forums/showthread.php?s=&threadid=67188
Guys, I think this will help some of you get a better idea of what you want.
Color Temperature (kelvins) vs. "Color" Chart
Google.com
mediacollege.com
-David
Google.com
mediacollege.com
-David
my local Lowe's store has the sylvania mogul based 400w mh bulb at the store in stock for like $27, they're like 4200k or something p# m400/u/rp look into it, i've got one similar that's by ge that was like $20 or so, my enclosure should be done tomorrow or the next day, i'll let you know how it turns out, but the bulb is bright as hell and really white
cool let me know how it goes would like to see how the box looks also. im going to be useing
10" projecten panel lcd
290mm fl lens
ir glass
2 220mm fresnels
400w mh light
if anyone thinks i should use dif. fresnels please let me know.
290mm fl lens
ir glass
2 220mm fresnels
400w mh light
