Goldwood GW-1038 for Dipole??
Taking the plunge...
Well, didn't get a lot of feedback on this one...
The drivers aren't that expensive so I ordered four of them. I'll put them in an H-frame cabinet and let you know how it goes.
Stay tuned -
Bruce
High or low Q, that is the question....
I am struggling with the concept Q in terms of an open baffled woofer. Many poeple on here are saying that high Q will need less EQ, but then it seems that there is way to have clean bass with a woofer that stores some much energy......can someone elaborate further?
Greg
Re: High or low Q, that is the question....
With all due respect to mike.e those guidelines are meaningless with regards to your question.
The point of the high Q is to pick a driver with a large bump in the low freq response so that if you just trim down it's upper end plateau with your low pass filter you can get very close to a flat freq response.
If you go to diysubwoofers.org, download Brian's dipole.xls spreadsheet you can play with driver parameters, baffle size, and LP filter until it becomes clear.
Yes, I get this, but then how does this fact NOT translate into sloppy bass with no pitch definition? This is where I'm not making the connection, because the same high Q woofer in a box would be very sloppy sounding, even if EQ'ed back to being more flat of a response, right? This is due to the stored energy correct?
That seems like a bad thing. Maybe this is why Mr. Linkwitz chooses a low Q woofer needing lots of EQ to get back to a proper freq. response.
Greg
