I am selling a pair of Mono Blocks. The PCBs were bought from this thread
http://www.diyaudio.com/forums/solid-state/174468-very-best-amplifier-i-have-ever-heard.html
It was a group buy, designed by Naggy'sAudio, PCB layout by Alex MM and group buy organized by Bigpanda.
What I am selling is:
2 Complete Mono Block Enclosures
2 Fully Stuffed PCB boards
and all the misc parts needed to complete these amplifiers
EXCEPT for the transformers.
You will need 2 400-600va transformers with dual 40v secondaries
and a 2 60v transformer for the protection circuit.
All the hard work is already done. The heatsinks are drilled for the TO3 output transistors. You will have to wire up the output transistors to the PCB board. Purchase and install the transformers. Wire up the input and output terminals. Then you can fire up the amplifiers. You will need a scope or someway to test and adjust the amplifiers.
I am selling these dirt cheap
I have $600 + invested so far and many hours of time.
The heatsinks and aluminum (1/8" top and bottom plates 1/4" front and back plates) for the enclosures total $300
Original BUZ901 & BUZ906 output transistors purchased from NEWARK $114
PCB boards $40
Caps, resistors, relays, transistors, diodes, terminals... $165
$619 total
Im asking $350 + shipping.
Uploaded with ImageShack.us
PCB boards $40
$619 total
This is a Goldmund Mimesis 9.2 clone
Here are the specs.
GOLDMUND MIMESIS 9.2 MONO POWER AMPLIFIER - SPECIFICATIONS
250 watts into 2-8 ohms
Here are the specs.
