Gold/Brass coloured switch?
Hi guys, just asking here if anyone knows where I can buy a gold/brass coloured switch,toggle or push button, SPST is all it needs to be, to use as a power switch on in a class A amp with a timber front panel. I've seen on line switches advertised as guitar switches which select between pickups but cannot find any electrical specs for them. I thought maybe kitchen appliances or the likes may use gold/brass coloured but cannot find any either?
Mouser carries a large line of switches.
I tend to use a light-touch momentary pushbutton, metal-faced, to trigger a simple circuit that kicks on a power relay of a standby supply.
That way, a larger selection of switches can be used, only needing to "pulse on/pulse off"a few mA of current.
Yes Mouser do have lots and have had a look here, lots to go thru and still searching.
The idea if using a smaller switch to switch a relay also occured to me, nice to see others think the same
