Hi all,
Can someone recommend a good circuit for testing if an op amp is still functional vs. dead? I've tried to search the forums, but the algorithm dislikes anything with less than 4 letters... . Googling has shown me a few options, such as:
Dual Op Amp Tester Kit (#6783) | NightFire Electronics LLC
and
Tester for 555 Timer and 741 Op-amp ICs - RadioRadar
However, these won't work with all op amps. For example, the first one has issues with any op amp that isn't unity gain stable. I know that a simple go / no go is a fairly complex issue when it comes to op amps and there is a lot to take into account. Is there anything out there that could do the job without needing a scope and multimeter? Heck, even something Arduino based could be fun.
Thanks guys
and
Thanks guys
The NightFire plan should work even with fussy opamps. The HF gain is near infinite, not unity; and the PFB will slam it around anyway.
It is "possible" a way-off-spec opamp could flash the lights yet behave badly in more critial work, This is the flaw in ALL "testers"-- they test what they test, not what you need in your specific case.
