Go FR? Keep what I have? Improvements?
Hi all,
A few years ago, I built a 2-way system with Fostex FE83Es and Dayton DC-160s. I plotted the tapered quarter wave TL I wanted, and favoured 'bass' over the midbass...
And after two years of listening, and some recent measurements, that dip is there! It's there and it's very noticeable. Orbital's Impact USA(The World is Burning😀iversion) lacks what it should have. Actually, anything Orbital for that matter doesn't sound right! 😀
Thus, I wonder... Plus, my valve amp will be on the way from Ireland in the next few weeks (Immigration...don't start) and I'm wondering if 88dB will cut it. That's on paper, and I have not yet modded my measurement mic (WM-61A) to check the real-world efficiency.
Rear-loaded horns for the DC-160s? Space and WAF are not really an issue.
I have zilch complaints for for the FE83Es. I'd be sad to retire them in face of a fullrange - I'd like to keep them and fill out the <300Hz area properly. Right now, as you see, it's lumpy. I'm at work on lunch and cannot post my sweeps, but suffice to say, the dip is there!!
XO'd originally at 300Hz each, first order.
Does MJK's spreadsheet model floor bounce? It looks like midrange ripple from the TL, not floor bounce.
You can check whether its floor bounce by modeling the speaker and its floor reflection in Edge. Make the mic distance and location the same as that used for actual measurements. Results are pretty accurate.
A woofer close to the floor will have its first dip from floor bounce pushed higher in frequency. It should be crossed to the mid/full range driver, which is at ear level, before the first dip, and the mid/full range drive should be crossed above its first dip.
I thought as much, Ra7. That dip disappears if you model the line stuffed to hell. I think it's destructive interference from a standing wave established in the TL. Also, measured dip is there at 50cm, 1m and listening position (~4m). It's from the TL, definitely.
I reckon if you moved that Fostex off-centre things would improve quite a bit.
Try taking it out of the box and putting it on a baffle (cardboard will do) and have it offset.
I would also consider dual woofers purely for the fun factor with one close to the floor.
2.5 way
Sound bounces off all room boundaries. Usually there's a ceiling too, hence my move to dual woofers one at the floor and another up by the midtweet. I think I'll do another of my early (1980 or so) successes that had two 8s and four peerless cone tweets. I didn't know anything but I was young and I was improving, like J Mellencamp says. It made music.
Do horns have such nulls? I believe not, and their coupling to the room is better - from what I've read! I must sit over hte weekend and read up on theory!
The null that you are looking at is typical of end-loaded TL's. By placing the driver some distance down the pipe, this null can be pretty much eliminated. Exactly where the driver should be depends on the taper ratio of the pipe. For a straight MLTL, it's 25%, more taper, closer to the closed end of the pipe.
Bob
Hmm! In that case, as I thought, a complete rebuild will be necessary. A few hours need to be spent with the spreadsheets. I was considering horns, as I'll soon be using an amp less powerful <5W/ch, and will need very efficient speakers - which are often full range...which often need more reinforcement lower down. Or - to use the same drivers that I have, and rely on the horn's acoustic gain (a large rear-loaded for the DC160 and front-horn, for want of a better term, for the Fostex) to make up for the electromechanical inefficiency
