GM9601 pioneer
The port near the driver IC ,whats it for?
Do the FETs heat up and cause an increase in current draw when tightly clamped t othe heatsink?
I've never tried using a loading cap in place of the FETs in an amp using this IC. While the IC is readily available if damaged, it looks like it could be difficult to replace.
In most amps, using a cap between 0.01 and 0.1uF is safe but I don't know in this amp.
This appears to be a self oscillating amp. Have you removed the FETs yet to see if it is clocked or self-oscillating?
I view the output signal of a working amp and the High side signal dont look good like the working amp.
signal on first and last leg
10v/dv 5/us
