WARNING: Tube/Valve amplifiers use potentially LETHAL HIGH VOLTAGES.
Another possibility would be to use non-corrosive silicone sealant to glue a piece of silicone/glass composite sleeving around the plate contacts once the wires are soldered in place on the socket - neat, sweet, no fuss.
I built my GM70 sockets using drilled out teflon septar sockets . Contacts are modified bullet crimps and the whole thing is held together with a teflon disc and fixings . A few of these are available if required
