Gm-D8704
I replace two capacitor in the output filter circuit.The replacement getting hot and will sometimes cause the amp to draw more current.
What can cause them to get hot ?
Why is it going into protect? Excessive current? DC offset?
The ICs with on-board over-current protection sometimes refuse to power up without the outputs in the circuit. The low-side can be defeated but that requires adding a jumper on the IC and the IC isn't available if there is a mistake.
