Hello all,
I am attempting to restore an old RCA speaker. I was wondering if anyone here knew what kind of adhesive most manufacturers used.
I am refering to the shiny black glue, that most older paper cone speakers had, holding down the voice coil wires.
My speaker has a 'damping ring' and 'diffuser cones', also glued with this same substance and I would like to put them back with the same.
Thanks, Eric
Thanks, Eric
BUMP
After extensive searching, I had thought I had found the correct adhesive; "Airflex 400".
But upon finally obtaining some, it turns out to be a clear/white glue.
Surely someboby has tried to get the 'shiny black' glue to recone/recap/rewind some speaker.
Please help. I have googled my *#@ off, to no avail.
Thanks, Eric
Thanks, Eric
Geoff,
Thanks for the reply. For the 'diffuser cones' I carefully scratched the adhesive away with an xacto knife. (Slow and used a suprising number of blades), as it was in a 'bead' on the surface.
I am replacing the surrounds, but the foam damper was also glued on with it and I have a new one.
I have restored cars, amps and furniture. Restoring a paper object is new for me. I will check into bitumen paint. What is it used for? (In case we have a different name for it here).
Eric
Eric
