Yes I mean laquer layer.
My design need to glue long wood-slats directly to the laquer (firts paint and then 6-7 layer laquer). So, no wood-glue..I dont like to use super-glues also like SuperAttack, because IF I am gonna mess up something, it will mess up the surface, even IF one drop of glue woud fall on the surface! So I need some good, strong glue, which wound dry so fast...
rinx said:Good morning!
The question is, what kind of glue to use, when the purpose is to glue long and narrow wood-slats on the speaker (piano laquer) ?
Wood-slats are only 4mm wide...and 1000mm long
Thank You
Contact cement.
- Glue and laquer
