Global Feedback - A huge benefit for audio
Spacial cues in mono could be, for example, reflections of trumpet sound from side walls, back wall, and ceiling. Certain time delays and intensities of these reflections make kind of one-dimensional footprint of the instrument and microphone located at fixed positions in the hall.
If you had a mental aural map of the hall gained by experience of being there that might help your brain construct an image of how the instruments could have been arranged, but none of that imagery is actually coming from the speaker. I think it would also help to have wide dispersion in this instance. But how could it relate to distortion, which is what this thread is about? I mentioned negative phase HD2, anything else?
Audio is about reproducing music for a human listener.
The human is the ultimate judge. There is no escaping this.
Denial is futile.😎
Human perception can be modeled.
Example:
If you living in a country with 4 season, maybe you think 22 degree Celsius of room temperature is "hot". But for me, it is "cold".
Sound reproduction should be made accurately, but most people do not have idea which is accurate. They only know which is sound better. Some designer make the model of some preferences, example: some people love H2 distortion, other just love high SPL, etc.
The concept of well designed amplifier could hardly be more vague. It is much easier to interpret distortion figures than designs. The fact that distortion figures are design-independent and do not differentiate between amplifiers is insignificant in this context. Distortion figures serve as a substitute for technical understanding and the capacity to make subjective evaluations.
Transistors are non-linear devices. Feedback helps to improve and linearise them. Textbooks about electronics explain that in detail as this is one very important foundation of electronic circuits.
The definition of feedback is: a part of the output from a system reaching the input and adding to or subtracting from it. This is elementary control theory.
A degenerating resistor connected to the emitter has the output current component flowing into it and creating a voltage difference which subtracts from the signal voltage which is usually applied between ground and base. This is negative feedback.
You continue chanting the monotone feedback mantra. Instead of blindly memorizing shady textbooks, you should think for yourself.
You are not in position to prescribe what I should or what I should not do here, as long as I follow the rules. Inadequacy of measurements is a relevant issue.
Of course not. But you do agree terms like 'micro detail' are entirely subjective.
I suggested that if an amplifier is linear and accurate - and then lets say has a low noise floor and has plenty of power - it will reproduce exactly what it is fed on the input with enough power to drive a speaker, then the terms you use are meaningless.
Micro-detailing can make sense when the feedback amplifier has transient overshoot (ripple).
Different behavior with a small signal and a large signal.
THD is just one of the characteristics - stability, speed, overload capacity, clipping ...
You’re invoking problematic amplifier behavior that is easily resolved using control theory techniques with the ability to discern something that is a purely subjective concept and has no meaning in the real world.
Try again, but this time with an amplifier that does not suffer from ringing and overshoot - be it ZGFB or with GNFB.
Often, a music signal looks like a low frequency envelope with high frequency noise, modulated with 100 Hz if considered pink noise. So much for the microdynamics - when you clip, the highs and mids are the first to suffer (the main informative part).
How does this have anything to do with amplifiers that employ feedback not to be able to deliver ‘micro dynamics’
Can someone here define the term objectively?
