hi every one
i built up the Giesberts HEXFET AMP with the IRF pair and after i finished i started to measure the offset and till that it was fine ... then when i put my multimeter in series with the positive supply rail and strated to adjust P2 but i found that the quiscent current is fixed at 3mA not changing so i checked the transistors but it was all fine however i changed the TR7 with another one but the same result and when i tried to apply an input signal i got a clear good output sound but very low power arround 10 or 15 watt .. i don't have an osciliscope so ..... please help what my cause this ?????
and here is the link of the schematic :
http://www.mif.pg.gda.pl/homepages/tom/files/120MOS.gif
