Getting no projection, tried messing around alot with fresnel, no results... plz help
Well, right now the Ushio bulb that many people use is backordered (everywhere) until Feb or March.
Check Atlanticlighting for a good start. Just do a google on Metal Halide 400W bulbs. Be sure to match the bulb with the ballast. MH bulbs have a MH ballast. HPS (high pressure sodium) bulbs have HPS ballasts. There are magnetic and electronic version for both types of bulbs. Don't be afraid to call the company right up and ask them about things. They are more than willing to help. 🙂
I've tried Atlanticlighting, didn't get much out of it...
so I tried some good ol ebaying! here is what I found as a bulb:
http://cgi.ebay.ca/400-WATT-METAL-H...581644050QQcategoryZ58144QQrdZ1QQcmdZViewItem
it's around 36 000 lumens! 🙂
Now I'll look for cheap socket/ballast, again, if you have anything to recommend :smash:
That's a decent bulb, but the color temp is a bit low on the spectrum at 4K. Ideal is 5.5-5.7K, and the Ushio bulb that a lot of us are using is 5.2K. That Phillips bulb is vastly superior to what you were using though, and nobody has the Ushio in stock right now.
Citrusxt,
Do yourself a favor and pull the lcd from the equation for the time being. Make a transparency of a fine black horizontal and vertical lines the size of your 15 inch lcd. Tape this to a piece of glass and use this as your lcd.
Actually do the alingment with no lcd or trasparency in place first.
If you dont see a sharp bulb image at about 32cm from the top fresnel there is no point going any further.
Now check your alignments and distances with this. Remember the bulb arc needs to be centered to the center ring of the fresnels. You should see a reasonably sharp arc image of the bulb at around 30cm from the lcd.
