I saw the 70V tap on the output. This is (if I recall correctly) for stringing a long series of small speakers for background music or PA.
It may make a good guitar or vocal amp. It is probably designed to not waste power on lo-freq.
Might want to find someone with a tube checker.
If there is any sort of puddle of black potting compound underneath the power transformer or output transformer, or if the wires are black with it, then it has overheated. The black potting compound melts and flows down the wires.
If it has a tube rectifier then it may be OK because they restrict maximum current, but a solid state rectifier will not limit current when the filter caps leak. I see solid state rectifiers on the schematic, so you might want to check the transformer leads. If it has gotten hot it could still be OK.
You need to check all of the resistors. Carbon composition is notorious for going as much as 100% out of tolerance.
So in other words it is bad at producing low frequency or it is good at it? What do all those screw things in the back do anyways?
I have a question about buying capacitors. I need 5 .02 MFD 400 VDC. I have read that MFD means that it is in uF measurements. I have also read that the voltage can be higher than what is needed because it is a maximum. Do I need to replace these with the exact same type of caps (close to impossible) or can I use .02 uF 600 or 1000 volt ones? Also does it have to be the kind with the liquid in them, or could I used film type ones? Thanks again.
You can replace those .02uF caps with a modern film cap of 0.02uF - 0.022uF (current standard value) with any voltage rating equal or greater than the original part.
I would start with the power supply and work from there.
Before you go very far I would verify that this power transformer is infact ok.
I would also recommend you read and familiarize yourself with the high voltage safety thread here:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=30172
Something that would be useful in trouble shooting is what I call a ballast lamp - basically a lamp wired in series with the hot side of an extension cord. Has the nice property of limiting current and preventing serious component damage.
Check that power transformer by disconnecting and insulating the high voltage and bias secondary leads. Remove the tubes. Use a 100W lamp in the ballast lamp mentioned in the last paragraph. The bulb should be extremely dim and the filament voltage should be close to 6.3V.. Refer to the schematic for AC voltages for the bias and high voltage winding and measure them carefully. If the bulb glows brightly with no load on this power transformer that is a very good indication that it is toast and you will need to decide whether you are committed enough to spend the money for a replacement.
Once you have confirmed the power transformer is ok, then you should go ahead and replace the rectifiers and ALL electrolytic caps.
Paper types in the power stages should be next and last and least critical to the safety of the amplifier (should still be replaced) are the coupling caps in the small signal stages.
This PA amplifier should make a very nice vocal amp with a little work. Webster (IIRC) made some pretty decent PA amplifiers. PA amplifiers deliberately roll off the LF response to limit the amount of power required to do the job, that doesn't mean that it necessarily has a bad output transformer either. Vocals don't need a lot of power below 300Hz or so, so I doubt this is a real concern here.
As Chris suggested a good DVM would really help you out, the odd readings you get with this meter are probably due to resistances above the range of the meter. Fluke meters are durable, accurate, and unlike cheap meters are generally forgiving of mistakes as long as you don't exceed their maximum rated voltage.
Antique Electronics Supply at www.tubesandmore.com is a good place to get a lot of odds and ends needed to fix this thing. (I have no affiliation with them, but have been doing business with them since about 1990.)
Hi Kevin,
Thanks. We are in agreement.
I personally think this will be a great vocal amp, with power to spare.
Hi Mark,
-Chris
Hi Mark,
The generalizations you are making will often be far off the mark. Old Bogen amps were pretty good with no shortage of bass. I had a CHA-75A that I fixed up for a bassist. He kept blasting the woofer VC out of the gap. He also commented that it was a killer amp. This one looks to be similar.I don't mean to rain on your parade, but you may be disappointed with the results.
-Chris
I thought he was going to use it for reproduction of recorded sound. I did use the word may. Sure, it is great for vocals, that is what a PA amp is for.
The yellow caps may be OK. They are Cornell-Dubilier WMF film/foil polyester. They are of modern technology.
Wow that tubesandmore site is cool. I'm still trying to hunt down certain parts. I can't find a 200 MDF cap. The same site has 220uF ones. Is that too far off? They also have 100uF ones. Could I put two in parallel? What's with the 5% and 10% tolerances? I can't figure out what the old ones were.
DeadSpeaker said:Wow that tubesandmore site is cool. I'm still trying to hunt down certain parts. I can't find a 200 MDF cap. The same site has 220uF ones. Is that too far off? They also have 100uF ones. Could I put two in parallel? What's with the 5% and 10% tolerances? I can't figure out what the old ones were.
I'm in agreement with Chris on this one, with a little TLC this should be quite a nice vocal amp, and should be suitable for some mods once working to fit it even better to the task..
To answer backwards, most likely the old electrolytic caps were +80% to -20% tolerance which just means that a nominal 200uF could range from about 360uF to 160uF in value, modern caps can be much better than this.
In the case of film caps with 5% - 10% tolerance should be fine for signal caps in this application, you can match the output tube coupling caps to a tighter tolerance than this if possible with better LF balance resulting to the output tube grids, not critical though. (A very little less distortion)
You can use a 220uF capacitor without a problem. I wouldn't bother with 2 x 100uF in parallel, it's a bother and one more component to go wrong later..
Do the transformer test I suggested before going too much further though, and do read the safety thread before the nitty gritty of troubleshooting the updated amplifier begins.
Glad you like the AES website, quite useful, lots of stuff for these sorts of repairs in one place.
If the amplifier has CDE WMF those are mylar or poly films and as long as they are not physically damaged should be fine without replacement.
All of the yellow ones are cde wmf. I haven't gotten a good meter yet, but the one that I do have does not pick up a reading on any of them. I am getting a reading from the diodes so I don't think that they are blown (because I only get the reading one way). the majority of the resistors seem to not give readings. I don't know if this is do to my meter not being very good or if it is because they are actually shot. Now what you said about the transformer test is very confusing to me. Are you saying to take an average table lamp and connect the plug to the transformer? Do I take the transformer out of the chassis? Where is the power coming from? Thanks for the help
Don't remove the transformer from the amplifier..
Go a local home center or hardware store, buy a lamp socket and extension cord. Identify the hot wire (usually the smooth insulation side of the extension cord) and cut it so you can wire the lamp socket in series with the extension cord hot. The amplifier plugs into the extension cord, cord plugs into isolation transformer if you have one or directly into the wall if you don't. 100W bulb in socket.
Disconnect the high voltage and bias windings from their respective rectifiers. Insulate..
Do tests as previously described. Be careful as high voltages will be present if the transformer is good or bad.
Did you read the safety thread yet?
Resistors that measure open on your meter might be good or bad, sounds like the meter doesn't have the range required. Meters generally read open on caps unless they are bad. (shorted) WMF will not need to be replaced.
Halt! and prepare for the job
Hi DeadSpeaker,
Please stop right now.
Given that your meter is very suspect, please put this project to the side until you get a good one.
Your current meter is probably lying to you. You can still use this one after you check the voltage readings against you new good one. Then just use it for measuring DC volts. It's always very handy to have more than one meter about.
Meantime, read the safety section and other threads where guys fixed a tube amp. I know you want to jump right in and do it, but I want you to be successful. This might be the start of a great hobby if you enjoy yourself.
So do not trust any resistance readings yet, especially on capacitors.
-Chris
Hi DeadSpeaker,
-Chris
Alrighty, I'll look into getting a better meter. Then I'll know exactly what to replace. I want to try this transformer testing thing so that I don't waste time/money, but I'm lost as to what to disconnect and where to do so. The 2 rectifiers have 8 legs on them and they are numbered. The schematic has 6, 7, and 8 as the ones that are being used. Is one of these where I make the break? I'll won't do the test right away. I'll look into everything first. Thanks for all the help.
Hi DeadSpeaker,
Good plan, I'm all for that. If you don't want this amp, I'm sure there are plenty of people who would, even broken.
The good news is that you didn't detect "that smell". So there is much hope. What I desire for you is the minimum money spent on parts and the best performance. That means you will be a happy camper when you are done. So things I may say are for that reason.
You have found a jewel as a first project. I didn't know what you had stumbled upon until I saw the schematic tomtt kindly pointed out for us all. I'd very much like to see it back in action.
Start by simply lifting one side of each diode, don't cut the lead unless you will be replacing them. If you see any disc capacitors across a winding, lift one leg of those as well. Unplug all tubes for this test.
To make the current limiter as Kevin suggested, buy some 3 conductor AC wire, 18 gauge should do it. You'll need an AC plug and an outlet (put it into a standard electrical box, everything mounted on a piece of wood) plus a screw in light bulb socket. You can include a switch if you want. Also, an assortment of light bulbs, all the way up to a couple hundred watts (for future) and down to 15 watts or there abouts. These will be installed into the socket to limit the current. The lamp determines the limiting (thus the different lamps).
Wire the line (from plug) in series. The hot goes to the switch, the lamp socket and then the outlet. This is all in series. The other side of the plug goes right to the outlet. The ground goes to each box to keep you safe. Do not fail to connect the grounds right through!
-Chris
-Chris
Hey Kevin!
Hey Kevin,
Do you have something you can do a schematic with and post your current limiter in the high voltage thread in tubes and solid state? I think it's easy enough for most people to rig up and use.
I'd rather that than have someone say "Ain't got a variac and I'm not about to buy one, so here goes ...... POOF!"
Most of my computer stuff is down right now. If you can't or don't have time, can someone else do this please?
Thanks in advance if anyone can do this.
-Chris
Hey Kevin,
-Chris
Even if the 4 diodes were removed from the circuit, the resister that are in parallel with them would still be making connections. Do you know for a fact that this is all that I have to disconnect? And once the light lights up, does that mean that the transformers are good?
Hi DeadSpeaker,
All you need to do is lift one lead from each of the five (5) diodes and you will be okay. Remove the tubes also.
The single diode is for the bias supply. These look like standard rectifiers. The band marks the cathode.
When you power this up in this fashion, the light bulb may flash briefly but should not light up or glow. The only thing that should draw current are the transformer eddy losses. These losses are normally small in an open transformer unless there is a fault somewhere.
Try not to move the wires around to much so the insulation isn't damaged.
-Chris
-Chris
Yes you need to put a fuse in to complete the circuit.
It's not a bad idea to have someone around when you are doing this sort of stuff in case of accidents. Moms tend to get wigged out by this sort of stuff, Dads are a safer bet. My parents looked the other way even when I let out the magic smoke, perhaps yours will be as understanding. (And this was in 220V land incidentally..) I was generally very careful as you should be.
It occurs to me that safety is a concern you might want to also buy a GFI/GFCI (ground fault interuptor at the local hardware store, get a 3 wire cord, plug (or buy a replacement appliance cord) and mount the GFI in a box - this will provide some additional protection to you in the event that the transformer insulation is bad or there is a death cap on the ac line side. (This should be removed if present!!)
Hi Kevin,
There are so many things I take for granted now that are done without thinking. Most for us work on autopilot while we look for other clues in the equipment.
-Chris
Fer sure!this will provide some additional protection to you in the event that the transformer insulation is bad or there is a death cap on the ac line side. (This should be removed if present!!)
-Chris
anatech said:Hi Kevin,
Fer sure!
-Chris
One other thought is when you do get this thing working it would be an excellent idea to put a three wire power cord on it since it will be connected to microphones that you may be touching while playing a guitar.. A good recipe for an electrifying experience if there was one.. Good idea regardless...
Test results are in:
I took an on AC computer cable and cut the pc end off. I figured out wich wire was which prong and connected on of them to one prong on the end of an actual lamp. I used some wire and connect that other lamp prong to the other prong on the amp cord. The remaining prong on the amp was connected to the other blade of the Ac cable. I plugged it in after I through the switch and stepped back. The light did not come on. I put the switch the other way and the light came on. The fuse didn't blow or anything. I plugged it in to see what it would do with out the tubes or diodes in and this red light came on. What do you guys think?
- Tubes / Valves
- Getting a vintage amp to work
