getting a pop when i power down, help
i have a Cayin ta-30 (el-34) hooked up to a passive pre which i run with a Single driver set up. The amp runs 4 el-34's biased at 350 to give it 30 watts.. The amp is set up so that you can take out 2 power tubes and bias it to 700 and it becomes a SEP (4 watts). Everytime i do this (with a pre or without) i get a pop through the speakers after about 5 seconds when i power off. I turn all the volumes down and still get the pop. the pop dose not happen when all 4 tubes are running only when i take 2 out and bias at 700. I built the speakers , interconnects and speaker cables which all work well with my other gear. Am i doing something wrong? can it be fixed?
Any ideas would be helpful.( my technical knowledge is not great)
Thanks.
