Germanium (SiGe) rectifier PMEG120G
That's not germanium, its silicon germanium, an alloy. SiGe can have many different compositions, and a lot of "SiGe" devices use heterostructures so its a complex subject. The diode specs suggest fast reverse recovery characteristics. Its only rated at 120V though which is low for a general purpose rectifier.
120v is plenty for use for amp/preamp/dac
Many SS power amps require more reverse voltage than that! Even +/-50V supply is probably too borderline to risk it (unloaded voltages can be significantly higher than rated voltage).
And then there are mains transients to consider. I'd suggest 200V or 400V PIV is a good spec to go for for general SS power amp use, especially as cheap bolt-on full-bridge rectifiers are available in those ratings and will be for the foreseeable future too. Fast recovery are only really useful for switch-mode supplies which I think is what these SiGe diodes are designed for.
I live in a small space and my amp runs on +/-18V. So it's enough, at least for me. Even so, those diode can certainly be used on preamp/dac.
I understand the key is noise or soft recovery. The datasheet does say it's fast and smooth. So I am curious.
