Gentlemen, I'm in my first StereoWar !!11!1! in 3 decades!; and I'm kickin' arsh! ;)
Now I get it - he wants a multi-sub phase-switch remote control! Imagine to click through all possibilities without leaving the listening position
Yep, easily done if you've got the cash. I've got a rack of Powersoft T-series amps here. Connect them to a network, run Armonia+ on your PC, and you've got access to a crazy amount of DSP, and enough amplifier power to turn any HiFi driver inside-out.
There's also variable output impedance for drivers operating below 400Hz.
Alternatively, put the pots or switches on looooong wires run to the listening position. Spend an evening flicking switches while listening to music.
After a lot of messing around with my system, I've settled on something simple. These days, the best performance improvement I've found is a glass of something pleasant to drink, and turning the volume up a bit.
Chris
