no eq, and with genelec you can´t do boost
Looks like they EQ it flat to 30hz by default. I see this kind of of rising distortion whenever someone is using EQ on the bass frequencies.
Genelec should make a bigger 8351 and keep price the same.
here is distortions from small bassreflux speaker, there is distortion drop near vent resonance.
Can´t see same on genelecs graphs
I think you're better off with a horn that loads the coax driver lower, a lot lower. 🙂 Of course they have to build these things where studios can actually afford them.
Neumann KH 310 is better in this regard. And the KH 420 ist much better, of course (>110 dB @ 1% THD).
You mean 420 is much better?
