GB: New run Lynx 3.01 amp by Jan Dupont
Can I suggest an improved wiring arrangement for section9 of the pdf?
The two AC and centre tap be a twisted triplet to the rectifier.
The +ve,-ve and centre tap be a twisted triplet from rectifier to the smoothing capacitor bank.
The Chassis connection can as shown be from the centre of the smoothing caps.
The mains DC supplies +ve, -ve and Power Ground be taken as a twisted triplet to the amplifier Power input end.
Part way along this twisted triplet add a tapping point to the Power Ground.
Use this new point as the Main Audio Ground (Star Ground).
Take the RCA return to Audio Ground.
Take the Signal Ground and signal as a twisted pair to the RCA Hot and to the RCA Return.
Take the Speaker Return and the Signal hot/out as a twisted pair to the Audio Ground. Connect the Signal hot/out to the PCB and keep the Speaker Return continuous on it's route to the Main Audio Ground.
This arrangement removes the charging pulses and all the HF harmonics flowing between transformer and smoothing caps into a separated circuit that cannot adversely influence the circuits connected to the Main Audio Ground. This separation of Audio from Charging is important.
Andrew...It is alway's the best scenario to keep the power supply caps charging currents from the audio signal. To do that I typically use an CRCCC arrangement. The charging peaks on the caps feeding the amplifiers are much slower.
Also a double bridge arrangement allows you to place the star ground at the clean end of the power supply.
Here the pic
PR,
I do not see a twisted triplet from transformer to rectifier (your dual secondaries need two twisted pairs from transformer to dual rectifiers), nor from rectifier to smoothing caps, nor from smoothing caps to amp PCB.
I see three connections in the middle of the strap forming the Zero Volts. What are they?
Tara,
CRCCC does not ensure separation of charging currents from audio currents. It's the wire layout that ensures the separation, not the components used.
for every "circuit" that has a flow and return route then the pair of flow and return must have a low loop area to minimise pick up of interference from other noisy sources and to minimise the radiation of interference from this circuit.
Where the flow and return involve three wires (as in a dual polarity supply to an amplifier), all three wires must be formed into a triplet with low loop area.
Twisted is the easiest way to achieve low loop area and low interference with wiring.
Parallel close space traces on a PCB achieve similar.
