Signed up for one board, two +ve regs & one -ve reg components kits
I have sent you a PM.
Can i pay now, or do we pay later?
Private Messages sent
Tea,
I have signed up for boards, and one mini +, mini - UB kits. Ready to pay now.
Thanks,
Greg
Thanks,
Greg
Signed up for 4 boards and 6 positive mini kits and 6 negative mini kits. Ready to pay now.
I will send a private message with details.
FYI, each board contains 2 positive and one negative pcb. So 4 boards will max take 4 negative minikits.
Tea
This GB is excellent timing - I have just bought a DSD DAC in another GB (DSC2.5) and I am looking for some high quality power supplies and this is the place to get them.
Now the DSC2.5 uses both 3.3V supply (1 of) and 5V supplies (recommended 1 for each channel). I will obviously use a Reflecktor D for the 3.3V input, but it seems that I have a choice for the 5V supply - the Reflektor or the SSLV1.3. Does anyone have a recommendation. Note that I will use Reflektor mini board as I will keep all AC in a separate box from the DAC enclosure.
Thanks, Hazard
Thanks, Hazard
Signed up for one board, one +ve regs & one -ve reg components kits
Tea & Salas, I'm flattered by your efforts - thank you very much.
I just ran across these and am curious if these would be good to use in a standard B1 and a 5V Raspi music server as an incremental improvement over a wall wart?
Tea
Thanks. Edited my order on the sign-up spreadsheet to 4 boards, 8 positive mini-kits, and 4 negative mini-kits
Problem with the Rasp pi is that it requires significant current over 1A and up to 3A. It depends which rasp pi you have and what you have plugged into it.
Those that will be running 5V for unit and need a measured <7.5ma IDSS PF5102 in position J3 in their minikits. Please private message me so I can note this and send a measured PF5102 for use in J3.
Raspi 3B + IQAudio DAC with an external WD passport 2TB drive attached to one USB port.
- Group Buys
- GB For Salas SSLV1.3 Ultra-BIB
