GB: Fo-Felix EMI Filter for AC mains 120/230v; By Folsom
Possible X2 cap part substitution
Hi All--I put in an order for the specified parts from Destroyer OS's email sent last night. I noticed Mouser only had one (!) of the x2 caps, where 4 are needed per board (part # 80-R463I347050N0M). They listed re-stock date out to mid-July for this part.
DigiKey didn't have any of the same part number, either. Weird. It appears that manufacturer part # R463I347000N0M is the same as the one specified, except for a lead length of only 4 mm vs. 25 mm. Mouser is showing stock of R463I347000N0M at 470+. So, if the board thickness is less than 4 mm this replacement part should work, right?
Thanks;
limits
No! This is driving me nuts, too. I've ordered a few dozen of them over the years... Maybe we're being ripped off (again) by a commercial place. 🙂 Flattering, but annoying for part ordering.
Luckily there is Digikey & Newark, probably more places. When ever you see a mouser # you can just remove the first numbers in front of the first - and then search for the rest at digikey or other electronic sites. For example 8121-RC and 8120-RC
8120-RC Bourns Inc. | Filters | DigiKey
Also the Comoco's are unique, no one sells anything like them besides Coilcraft. And IIRC the 812X won a shootout back in the day so that's why it was used on the original filter and now this one.
It appears that Bourn, who bought JW Miller, may also be selling to other electronics businesses. This is only maybe slightly different in the plastic area but otherwise the same, and there is 1400 of them. CMT-8120 Triad Magnetics | Filters | DigiKey
