JFETs arrived today, Thx for the group buy! Now if I can just find the workbench below those other projects.... 😉
Got mine too! I’ve got two sets, should I use each quad before and after the Nutube or on the right and left channel?
Just confirming, I read before one set per channel but it looks to me that it would make more sense before and after the tube
I hadn't given that any thought, I suppose either way has some advantage. They all are within the original specified range so either way will work. I'm planning on installing mine with the tighter matching per channel with respect to the input/output of each triode.
Jeffrey
Overseas also on the way?
All Overseas shipped TODAY!! Sorry for the delay, my day job has been devouring all my time the last few days.
No problem! Thanks!
Do you have any sets left?
For now no sets left. However, I kept two for myself but I may not use one of them. I bought a board with the fairchild Jfets from the diyaudio store and I plan to do a side by side build of it vs the Algar emi board. They both have tentative homes, which could change, I'm saving a set of the Toshibas in case the quality difference is noticeable. Would you like me to let you know if I'm not going to use them? It maybe a while.
Jeffrey
What are most people using their 8 matched JFETs for here? I am just getting them for future projects not yet determined.
Some will be going into future ACA builds, socketed to allow reuse in other projects. Maybe another B1 (Korg). Maybe extra buffers for balanced preamp outputs.
I'm also trying to remember where I may have seen an N-type JFet differential input stage for something like the Aleph J.
ACA does not need any matching as I heard.
I'm using these 8 from here for Nutube Preamp.
A great place to get LSK170 if going that way is nacsemi.com... They won't match but the price is great!
That's correct, the normal ACA wouldn't need matched JFets.ACA does not need any matching as I heard.
I'm not building normal ACAs. 😉
- Group Buys
- GB 8 piece matched Toshiba 2sk170 BL grade Jfet's
