Hi guys,
I need help form someone that has build the sch. attached or from mr. Gary himself......
I would like to try it on my 12B4 preamp. But since I don't know much about this circuit I have a few questions.
First, mr. Gary uses 3.3V battery cells in the table in his article (from where I have the sch attached). I have 3.6V cells - and because of that I would need to adjust slightly the circuit. Would it be enough to use the same circuit as attached and adjust it with the pot as in the sch or should I change some values.?
Second, he has metioned that he uses 2,3 or 4 cells- I asume that he use them in series with. So if I would decide to use 2 cells I would need 4 battery cells for the whole circuit, right?
Third, and most important of all, what is the voltage drop across the ccs? Is it the same as in other revisions (150V)?
Hi grataku,
no I didn't since I know that mr. GP is very, very busy man. I thought that someone on forum might have played around with this type of ccs. So it seemed better to ask those questions here, on forum.....
best regards
daniel
best regards
daniel
- Tubes / Valves
- Gary Pimm's battery biased mosfet cccs
