First 6 pcs of Avel-Lindburg 500VA dual primary, dual secondary Toroids. Secondaries are rated at 40Vac, primaries at 120 each.
4 are in great condition, 2 are so-so with some wear on the outer tape, but pass 3000Vac dielectrics from primary to secondary.
1pc of a Amveco with 30Vac secondaries, based on size only, probably 300-400VA.
1pc of a no-name transformer with 28Vac Secondaries, based on size only, greater than 500VA
$10.00 each for any of the above, I can ship in the flat-rate boxes for $11.00
2pcs - Seas Coaxial Tweeters. These can be mounted inside any of the drivers with the 29mm voice coil. $20.00 each, Ships in the small flat-rate box for $7.00
ClarityCap DTAC Capacitors - Sound great, 3uF, 6uF and 15uF sizes. These were crazy expensive when new, maybe 100hrs playing time on each, great condition. $20.00 per pair, Ships in the small flat-rate box for $7.00
VPIHW19 MKII - Big, Heavy, needs a belt and general repair and maintenance. I bought it in need of repair and never got around to it. I paid about $200.00 for it. You can buy it for $100.00, send zip code for shipping.
Dantimax Remote Stepped resistor attenuator - includes remote $20.00, Ships in the small flat-rate box for $7.00
Another remove stepped resistor attenuator with display and remote $30.00 Ships in the small flat-rate box for $7.00
You can see the pictures of most of the above here:
Pictures by PaulHilgeman - Photobucket
If you are interested - e-mail to pkhilgeman@gmail.com
PayPal to info@nomad-audio.com
Thanks for looking
Thanks for looking
