Gallien Krueger RB400 Bass Amp Adjusting the Bias Trim Pot?
In principle, do not mess with it.
Measure voltage drop across emitter ballast resistors, post it here, also resistor value, so we can caculate current.
I guess 20-30 mA per transistor would be fine, adjustment could be needed if , say, <2-3 mA (including zero) or higher than, say, 70-100mA
@JMFahey I read 986 mV DC across R26 and 1.028 mV DC across R27. With the 0.33 ohm resistors that would give me 2.99 and 3.11 mA.
I assume messing with R14 would allow me to increase these values.
FYI this amp was dead and I traced it down to Q12 being bad was which was a MJ15002. I did replace the two MJ15002s (Q11 & Q12) with MJ15004s, and both MJ15001 (Q8 & Q9) transistors with MJ15003s.
Feeding a 500 mV sine wave into the input the amps seems to work fine. Is there any components I should deal with before returning the amp to it's owner. I've read I should change a bunch of transistors. I do have some MPSA06 and MPSA56 transistors, but MJ15003 and MJ15004 transistors are on back order.
What are your thoughts on pulling the 8 power supply caps and replacing them with two 2,200uF / 63V caps?
Here is a picture of the PC board for my amp.
One thing I find interesting is if I plug my speaker into the 'direct out' the sound is very clean with no 'pop' when I power on the unit. If I plug into the 'SPEAKER' output it pops when I turn on the unit and there some buzz in the back ground. In both cases I'm feeding the amp with a 200 Hz 500 mV sine wave
@JMFahey I adjusted R14 to get the voltages across the bias 0.33 ohm bias resistors (R27 & R27) to 5 mV DC which is 15mA.
The owner of this amp is picking it up tomorrow so I hope this is OK. That's what it said to set it to in the service manual.
