gains with lm3886
Hi-
I've made an amp with lm3875 and several prototypes using the same chip. I'm starting a new amp and the lm3886 looks interesting. I was wondering what gains people were using. The data sheet says that gains between 20-200 should suffice. My initial thought was to use a gain of 20 as I had with the lm3875.
Is there a general consensus as to what gain to use with the 3886? There are of course obvious tradeoffs, but I'm curious to see what others think.
Also, I've never used the mute feature before. Do people typically have a physical mute switch or use an analog switch IC with a simple microcontroller or mechanical switch for control?
Thanks,
Doovieman
Doovieman said:
Thanks for the note. I'm not sure i understand what you mean with regards to the mute and a delay. Can you explain a little more clearly? Thanks,
Doovieman
If you check my QRP02 design (see my homepage) you can see how I have done the mute thing.
At power-up the LM chip is turned off totally under 12 V and over 12 V it starts to come alive but with shut off input stage which ends up in heavy attentuation. The datasheet has a diagram over current out from Mute pin vs. attenuation.
The result of my design is a completely silent turn on and since the buffers work under 12 V I have also a totally silent turn off.
I have used a bit higher value of the mute resistor in order to get a longer delay with choosed cap.
The mute and undervoltage feature is a really nice feature :up:
