Gainclone HUM, THUMP problems - The solution
AndrewT said:
Does anyone have a view on whether the two decoupling caps (in post1) should be connected together first and then taken to the Audio Ground?
My view is that they SHOULD be connected together, near the chipamp, and should also connect to ground very close to each other, there. Otherwise (or even additionally), another small cap should connect directly between the V+ and V- power pins.
Hi Gootee,
I have already sent him a private message with instructions on where to find the less dangerous disconnecting network and how to contact the moderators to remove the dangerous diagram and substitute the safer one.
It's just a pity he does not realise how many newbies may have read his first post in the intervening 17days of inactivity.
AndrewT said:
Hi Gootee,
Very good.
Agreed.
Mike514ml said:
I realize that the exact wire gauges may not be critical, but could you give me an idea of the relative sizes of the small, medium and huge ground wires?
Also, I'm currently finishing up a BrianGT 3875 dual mono chipamp kit (it's been lying around here for a LONG time), and was wondering if it would reduce the hum and thump potential more if it's built with single or dual power supply boards.
Hi Mike, I don't understand about wire gauges so I posted that picture (I have medium-size thumb 😀). Basically the largest wire is from good speaker cable about 4mm in diameter, the smallest is jumper cable about 0.5mm diameter. The middle size is about 1.5mm diameter.
Mine is built using single supply board for 4 channels. I don't know how using 4 PSU will help more as my amp is very quiet ie. no hump/thump...
Gainphile,
Thanks! The speaker return wire is bigger than I thought. I can work with this info.
Of course, it's kind of ironic that your amp sounds better if you don't use gigantic wire for the speakers! 😀 At least internally.
I think I'll go ahead and use a single supply board for my BrianGT amp, since I'm using a single (center tapped) transformer. It'll simplify the ac wiring. Of course, I'll stuff the largest wire I can into the ground connections!
Thanks again,
Mike514ml
In my own amp I have as follows:
Each channel's rail decoupling capacitor grounds have a common ground trace. This include the ground pin of the LM3886. This is returned via one fairly thick wire (same thickness as the power supply wires) to the central ground.
Signal grounds are seperated and connected at one place - the input jacks. This in turn is connected to central ground via a 10 ohm resistor.
Speaker grounds are returned direct to central ground. The zobel networks are on the output posts, so the speaker ground is also the return for the zobel.
The central ground is on the capacitor side of the supply - not the rectifier.
Central ground is connected to chassis earth via a 10 ohm 3W resistor bypassed with a 100nF capacitor. I could add diodes but I suspect this combination would allow more than the 30mA trip point of the household RCD to flow, so it is safe.
No hum heard at all 🙂
Signal grounds are seperated and connected at one place - the input jacks. ..
Hi jaycee,
I'm here in a little doubt since, for example, Mick Feuerbacher on his site http://dogbreath.de/Chipamps/ThreeResAmp/ThreeResAmp.html (comment with figure 6) connects the ground pin (pin 7) of the LM3886 to signal ground.
What should be the better approach?
No hum/noise with ear close to the woofer/tweeter with, let's say, a volume pot up to 12 clock?
Thanks,
Baka
Baka said:
Hi jaycee,
I never liked point to point construction. I also dont agree with a number of things in his design, for example, he has an outboard power supply consisting of the transformer and some 30,000uF of capacitance per rail - but then he has a small power supply connector with tiny pins.
His star grounds are at the chip. He doesn't really connect pin 4 to signal ground - he just doesnt have any isolation between the two grounds.
You can try it, but I would think it's more prone to hum myself.
No hum - some hiss, but no hum 🙂
Thanks,
Baka
On my system there's no hum with the pot at maximum, the amp is dead silent. I use a LM3886 at +/-30V, 3x4700uF/rail, 330uF/rail on the boards. Speakers have 92dBm efficiency. I will make a diagram to explain better.
Thanks, jaycee.
I have already implemented the point to point construction like it was explained on this thread, but on the gainphile's schematic ground pin on the chip and the way it should be connected is missing. Maybe LM3875 doesn't have the ground pin.
Other than that I discovered that a volume pot body itself (Alps blue) generates a strong hum and noise disregarding the properly connected its ground pins! When I touched the pot audible hum and noise could be heard through the speakers. I have tried then to connect a metal part of body to a central ground and eventually solved the problem.
Should I, maybe, connect the body via disconnecting network (R||C||D1||D2) to earth rather than power and signal central ground since the pot is additionally connected to extension rod and aluminum knob?
With my ~85dB efficient speakers with a volume pot up to 12 clock I can detect some hiss but close to the tweeter.
There you go, I hope it's easy to understand.
