Hello...
I'm a non-EE trying to learn about gainclones.
I've done some research around here, but haven't really found any threads with many discussions of fundamentals - primarily, lots of specific application and build discussions.
So, I thought I'd start one. 😉
I've got a few questions that I'd be highly grateful to receive answers on.
And I'm sure I will, this forum has amazing members, honestly. 😎
___________________________________________________
In my poking around here, I've seen some discussions that seem to put gainclone amplifiers on par with big dollar high-end home amplifiers.
How does the sound quality compare?
What design/construction factors affect it?
If the sound quality truly is superior - or even comparable - given the low cost of the componentry (save for the expensive transformer), then...
Why don't we see more commercial high-end chip amps?
I have several questions related to the comparison of gainclones to standard class A/B and class D amplifiers, and what applications one might substitute a gainclone, and what practical limitations exist with them.
Are gainclones class A/B amplifiers?
What is their efficiency, as a general percentage?
I've seen mention of class B even... and wasn't aware it was even used in audio... in fact, I had believed there was a forum of current switching noise inherent in it.
How much power can they be built for?
How much output power can I build a gainclone to produce?
How can I manipulate this in my design, if it's a design variable?
What impedance goals can be catered to?
Down to what sort of impedances can I build a gainclone to be stable down to?
I've seen many people using gainclones as full-range amplifiers.
Is the gainclone best suited for full-range duty?
Can it be built for subwoofer duty (ie. higher output power requirement applications)?
I read a review regarding a commercially-available amplifier that Peter Daniels designed, that included a special foot that could be equipped with a pad to change the "voice" of the amplifier...
Searching for more info led to some threads talking about gainclones being sensitive to vibrations.
How do (the explanation of the electrical/mechanics involved please) vibrations to the chassis affect the sound qualty / "voice" of the gainclone amplifier?
Is this one of these non-scientific things that certain people "swear" makes a difference, or is this a real anomoly?
Is it explainable?
As I understand it, the cost of the componentry is almost trivial, nominal... the exception being the transformer, for the power supply.
I've seen different chips being discussed.
What is the cost of the componentry?
Where can I best obtain the transformers and chips?
What are the differences between chips?
Why would I select one over another?
I've seen people discussing using DC batteries rather than obtaining the expensive transformer.
I'm also seriously involved in high end car audio, sound quality applications. The voltage supply by nature is DC, making this seem even more practical for car audio applications.
However, the question earlier regarding gainclones and vibrations to their chassis certainly could come into play, if that is truly a factor.
Could a gainclone be built to run off of a 12 volt DC supply?
Would this impart any limitations on the level of output power that could be produced by the gainclone?
I realize there are a pretty significant number of questions here, spread across a few general areas, but all tied to fundamentals, I think.
I'd love to start a gainclone project by springtime... and realistically, I can envision both home and car projects.
I'm already starting my research - I appreciate any help that can be given!
Is it explainable?
Could you be a bit more specific, please?
Yes, the gainclone is a very good amplifier (I'm not sure of any measurements) and you can probably build one cheaply and easily enough so it's not too much of a problem if you don't like it (unlikely).
Pick a schematic you think you can handle - they are everywhere on the net - and hardwire it together if you have enough experience; pcbs are apparently more hassle than they're worth. If you need help there are plenty of people who can help you with component choice, grounding (v important in GCs), etc, on the way.
Regarding battery power, speak to Roncla, usually found on Amp Chip DIY.com 🙂
my .02$ worth (where's the euro sign?!) 😉
sound quality is surprizingly good. Depending on build quality it out-plays many amps. Quite some Bang for few bucks!
WHat does not affect the sound of this amp... you tell me.
Dunno, there's not much to brag about. Maybe that's it. The only thing one can really say is that the GC philosophy (less is more) works...
yes, they are a/b amplifiers. My guess would be they're about 40-50% efficient.
There are a few designs out there for say 200W (audio power) amps. More than enough one'd say. You can do this by bridging or parallelling chips.
I wouldn't really use speaker sets with impedance below 4ohm.
yes, very well. for subs you could add more capacitance.
No clue. I have experienced this, though. Putting nice feet under your amps makes it sound clearer, nicer, tighter bass. I seem to remember a thread about this somewhere around here but searching didn't help.
Cost depends on how much you invest in it. You can build one from scrap or you can go exotic (thus expensive).
Selection of chips methinks depends largely on availability in your country. And again, cost. lm3875 is cheap, tda548/9 is more expensive.
A pretty lengthy post, all in all.
geolemon said:How does the sound quality compare?
Is it explainable?
This reply took a while:
Some equal it to $1000.00 to $2000.00 amps.
many, depending on who you believe.
I do not have the finances to pay $2000.00 for an amp with a $5.00 chip in it.
I think if I had a lot of money for an amp, I would go for a "classic" design, not GC.
for this section goto:
http://www.egr.msu.edu/classes/ece480/goodman/read_datasheet.pdf
This is a good article.
also, goto:
www.national.com and search for application note "AN-1192".
Yes.
much better than a class "A" amp.
An-1192 =--> 200 watts.
Generally limited by power supply voltage and heat sink size in high power amps.
hard to drive less than 4 ohms.
hard.
subs, mids, tweets, and FR.(may depend on speaker effenchency.
I built a "bridged" amp (2 ea. LM3886) in 1997 for a computer subwoofer using a 6.5" speaker ($10.00) - it rattled walls in a 20x35x14 foot room.
yes.
>Is it explainable?
IMO - no, YMMV.
Chip $5.00, resistors $50.00, Capacitors $50.00, connectors $35.00 ea, Case $big-bucks.
I will sell you a sonicly perfect transformer for $2000.00, on the other hand you could buy a plitrin for $65.00 (www.piltron.com) which most say works fine.
5 chips = 56 opinions. Most are using either LM3875 or LM3886
Power output, so and so says chip xyz is sonic superior to chip abc.
Using auto batterys is VERY dangerious, not for novice, I would never use them, not worth the risk. I would consider sealed Lead acid or Gel-cell.
Yes, Read Lm3875 datasheet - page 9 "output power vs Supply Voltage" = maybe 5 watts.
(I had to break for dinner, sharaz may effect many answers.)
also, goto:
Yes.
hard.
yes.
>Is it explainable?
IMO - no, YMMV.
Thanks for the replies so far!
I can't be more specific, because as I mentioned in my first post - there's lotsof information on this forum with respect to particular applications, schematics, chips, etc...
...but seemingly quite little on fundamentals, concepts, considerations...
The things that would lead you to choose one of those schematics, and the things that would lead you to select particular components and values, amounts of capacitance, etc...
That seemingly missing (and I'm hoping I'm mistaken!) information is what I seek. 😎
It's absolutely not my style to "just pick one" and run with it. 😉
My concern is obtaining the knowledge to let me select superior results... a means of planning, to get there. 😉
Maybe I'll build several, I'll probably have to. 🙁
It is true that I need something SQ-oriented, for home...
I currently have a QSC MX1450 here that I obtained more or less for stress-testing loudspeakers (I do R&D as a loudspeaker designer for a car audio manufacturer), but really haven't got anything with real finesse for my home system...
...it is killing me particularly upon my return back from CES 2004, where I spent a significant amount of time at Alexia Park, listening to systems where the two monoblock tube amps together cost more money than my house...
So, I'm sure I won't be disappointed, for the home. 😀
But I'm more of an experimenter... I don't just want to build, and enjoy, that's not my goal.
I want to explore, to learn, to understand these amps.
Get my feet wet (er... figuratively. 😀).
I'd much rather learn the concepts, the pros and cons, the ins and outs of these amps, and never end up with one of my own...
...than not learn the concepts, but end up with a pair of nice sounding amps.
It's not about obtaining a nice amp, it's about obtaining knowledge.
That's just fundamentally me. 😉
Just so that I'm clear, I'm looking to learn this unique architecture, which is "new-to-most". 😉Ropie said:Could you be a bit more specific, please?
That is quite simple. Use search function, type "gainclone" and read all the posts. Then build few amps and tell us what you think.
Re: Re: Gainclone basics for an enthusiast who's new to them
200 watts is definitely more than enough...
Do you know what upper-limit there is for a single chip based amp? 100 watts then?
I'll go reasonably exotic as needed, on functional componentry... or even a massive base to damp the whole thing physically...
...but I say that in part because it seems like we're talking about the difference between $2 capacitors and $10 capacitors... still "budget-worthy".
It's an amp for experimenting... someday, after I'm done playing, maybe I'll create one with an "exotic" look, hardwood & acrylic case, etc.
But, well, that's not what I'm shooting for right now. 😀
I do have one of my distributors in Korea, if that were somehow advantageous (heck, most solid-state transistor amplifiers are born, at least to some degree, in Korea 😉).
Worst case, I'm sure I could talk him into mailing me a chip... sounds a bit extreme though. 😀
...that just led me to having more questions! 😀
Thanks again, for taking the time to reply.. it's very much appreciated.
It's worth a lot more than that - thanks! 😀matjans said:my .02$ worth (where's the euro sign?!) 😉
OK, fair enough...matjans said:There are a few designs out there for say 200W (audio power) amps. More than enough one'd say. You can do this by bridging or parallelling chips.
Is this a fundamental limitation (ie. a function of what's built into the chips), or is this something that can be manipulated... limited essentially by how much current is flowing (ie. more current flows, given the same amount of power, at lower impedances)?matjans said:I wouldn't really use speaker sets with impedance below 4ohm.
Hmm...matjans said:Cost depends on how much you invest in it. You can build one from scrap or you can go exotic (thus expensive).
Well, in the good 'ol USA here, I'll have to hope I can get my hands on virtually 'whatever'.matjans said:Selection of chips methinks depends largely on availability in your country. And again, cost. lm3875 is cheap, tda548/9 is more expensive.
Yeah... I probably should have posted my original questions before bothering searching...matjans said:A pretty lengthy post, all in all.
Ah, if only it were!
I've been doing that for three days - and doing nothing but creating more questions. 😉
As I mentioned (twice now):
Lots of posts on particular builds, specific applications, "I finished my...", etc. all applied...
But very little, on basics, fundamentals, theory, or planning.
Try searching for
"gainclone basics"
"gainclone fundamental"
"gainclone fundamentals"
"gainclone theory"
"gainclone design"
"gainclone overview"
etc.
I've been at it for days... about three now.
It's time to start learning. 😎
I took nuuk's personal recommendation to search for some of your threads in particular, and while I can appreciate them (beautiful work), I just didn't find fundamentals.
Possibly, I'm misunderstanding things, from this "fundamentals" level:
I believe there are several schematics... I have seen four, so far... no doubt there are more.
I believe there are several chips... I've seen at least five mentioned (by model number), I believe there are more.
I believe there are several components and values - within the scope of a particular schematic (such as capacitance) that are essentially variables.
I believe there are reasons that I would choose one particular schematic over another...
I believe there are reasons I would select one particular chip over another...
I believe there are reasons I would select particular components and values...
Am I mistaken?
"just build an amp, and tell us what you think"
is like saying
"just buy a car... and decide later if that's the right body style, engine, suspension, tires, etc. for your driving needs."
(to draw an analogy)
See what I'm looking for?
Try searching for
"gainclone basics"
"gainclone theory"
"gainclone design"
etc.
Am I mistaken?
is like saying
My search is more than a year now and you want to have all the answers after 3 days? If you want fundamentals try to read chip manufacturers data sheets.
I still didn't get what you are looking for. I'm not so sure if you know.
gainclone is based upon a famous amp built by Junji Kimura, so called the gaincard. now, famous doesnt mean it sounds perfect, just that a couple of guys who hacked open the amp found out that it is using a cheap chipamp after all, and it defies a common theory that "all chipamps sucks". Ive never listened to a gaincard before, but from the reviews, it is quoted to be nicer/ if not as nice as those single ended silver wired bla- bla blah megabuck amps. So, knowing that we can build one of those cheaply instead of going to the store and buy one original, this is probably why caincard clone is so famous. And since we can get the chip for (almost) free, much of the discussions here are regarding the selection of external components to get more superior sounds.
The gaincard is built based on a few design philosophy, mainly that "less is more" meaning: try to minimize the physical components that the music has to go through. Thus the effect: it has very short signal pass and NFB length, only the very necessary external parts are used. Anything that is not critical:throw it away. The designer believes that any extra /unecessary conductors will degrade the sound signal. Of course, you cannot count in the million parts inside the chip itself. Also, contrary to popular engineering, the supply capacitors uses a very small value, so that almost none energy is stored in the caps. This is to the belief that the extra energy stored inside the caps will 'stale' and degrade the signal too. If i can get an oscilloscope, I can be expecting amost AC supply being fed into the amp. The amp relies on the high PSRR to reject ripples from the power supply instead.
All these design philosophies differ from the common/ popular design principles, but the end product still sounds good, and that is why it is so famous among us the DIYs
I appreciate it, very helpful!crown300 said:This reply took a while:
I'm curious why you say that, given the seemingly rave reviews I've read, in terms of SQ?crown300 said:I think if I had a lot of money for an amp, I would go for a "classic" design, not GC.
If you mean this in terms of "why isn't there more commercial product?", as far as spending money, I'd agree...
But, what of the "classic" amplifier that was $3000/per..
Compared to say, a Gainclone amp that cost... $300/per, say? 😉
Seems like "better value" would sell. Maybe it's just me. 😕
Gotcha.crown300 said:>What impedance goals can be catered to?
hard.
Well, that's just an experiment that I had envisioned...
I've got a particular application... might not work well for this, I can revisit this (or hey, maybe answer my own question! 😀) once I do understand these a bit more. 😎
😱crown300 said:>Could a gainclone be built to run off of a 12 volt DC supply?
I will... but I'm shocked at how low...
A stock car head unit can produce up to 22 clean watts per channel (due to "no power supply transformer" limitations) at 4 ohms at any rate...
Does this also apply to those who are running 12v DC batteries in the home, as well, as power supplies?
I appreciate your time in replying, thanks again.
Am I mistaken?
But those would be your reasons and nobody can know them better than you.
Are you mistaken? Yes, if you expect us to give you all the answers.
the sound
the most useful review of the Gaincard is the one at TNT-Audio:
http://www.tnt-audio.com/ampli/47gaincard2_e.html
this one actually talks about both the pros and the limitations of the design (quite on the mark - from my own experiences) and describes scenerios where it worked and where it didn't.
Most other review(er)s just gushed over the Gaincard like kids, and over-hyped the whole thing e.g. "as good as Ongaku", "outplays Krells and Levinsons", "the best bass I ever heard from an amp". Yeah, right.
Batteries -
+-12V (actually +-13plus V) can work if you have sufficiently sensitive (90db or more) speakers. If not, just double the batteries to +-24V.
P.S. By the way, I'm a Gainclone lover!
Batteries -
That's a pretty condescending and inconsiderate tone, considering you're simply thinking along the wrong lines, as to my intent... particularly considering you are making statements about my intent.Peter Daniel said:
"all the answers in 3 days" is an asinine statement. 🙄
A year is nothing to invest in a concept or field... I've invested longer in single projects.
Specific chip data sheets aren't fundamentals.. those are particular application data. Definitely useful once I know what I might be looking for, sure... but that "knowing what I want to look for" is the fundamentals.
Why would I be looking at any particular chip datasheet, for example? Why did I select that particular one, to look at? What do I know of it's purpose?
I want to learn how to select a particular chip's data sheet to look at.
I want to learn how to select a particular set of componentry.
There must be design variables.
Fundamentals.
I must have been led to the chip or schema it because it offered some promise of suiting my design needs, right?
Think basics.
Here I am... I might (or might not) have a particular application:
Maybe a full-range speaker, 4 ohms.
Maybe a subwoofer, 8 ohms.
Maybe an ESL panel.
Maybe a car audio speaker.
Maybe a custom low impedance application.
All different applications, right?
Whatever the application, possibly I say "Hey, I want to build a gainclone. Looks intriguing."
I'm certainly not just going to randomly select the first schematic that I find, build it, and then hook it up to see if it
a) survives
b) suits my application
That would be silly.
Would you buy loudspeaker drivers with the same lack of planning? Not by evaluating the specs, plots, modelling.... just crossing your fingers and hoping that it suits the cabinet and intended frequency range, power range, room application?
Of course not.
So, similar to selecting or designing loudspeaker drivers, I'm sure there are factors involved in selecting particular schematics, chips, components and values.
I'm not so sure that looking at particular chip-maker data sheets will help in learning the specs.
That'll tell me potentially what that particular chip is good for... but that's applied data. That's in the scope of that chip, were I to use it.
Let's use the analogy of loudspeaker parameters:
I have a spec sheet, and I see that this particular woofer has a low Qes value.
That's great, but it doesn't teach me what Qes is.
It isn't the source of information that says "a low Qes means the woofer has a strong motor"
It isn't the source of information that says "a low Qes essentially drives Qts low as well"
It isn't the source of information that says "a low Qts typically indicates particular suitability in a ported application."
If I had that information, I could do something with the knowledge from the loudspeaker's data sheet.
But... if I don't have those fundamentals behind "what Qes and Qts are, and what they influence", then the actual Qes value isn't going to help me realize what particular application this particular woofer might be good for.
I might not have a clue what to do with this particular woofer...
Similarly then...
Without knowing the fundamentals behind "what factors influence what schematic, what chip, what components, what values will be chosen for particular application", how can I even make a determination as to which potential application might be best suited towards having a gainclone built for it?
And then... even if I had one selected... which schematic/chip/componets/values would best suit that application?
Fundamentals.
If you know of better search keywords to extract these fundamentals, believe me, I'm there.
You are fundamentally misunderstanding.
A car designer doesn't know how to just design just one particular type of car, for one particular application.
A car designer understands that numerous variables exist, that can be tweaked to suit one particular application, or another:
* Interior seating configuration.
* suspension geometry and stiffness.
* engine HP and RPM curves vs economy
* tire compound and tread design
* wheelbase
* physical dimensions and mass
a loudspeaker designer understands that numerous variables exist, that can be tweaked to suit one particular application, or another:
* gap and voice coil dimensions
* VC former dimensions
* suspension compliance and CMS curves
* magnetic flux, given gap and top plate dimensions
* underhung vs. overhung vs. multi-gap architectures
* spider geometries
* single vs. dual voice coils
* cast vs stamped baskets
* cone geometry and material
What I am looking to learn, are the variables that exist, in designing a gainclone.
So far, all I know is:
* multiple schematics exist
* multiple chips exist
* multiple components exist
How do I learn what these schematics are good for?
How do I learn what chips pros and cons are?
How do I learn what components might be varied, and why?
These, are fundamentals. 😉
The schematics that I have found, were not in threads discussing the particular schematic in detail... rather, was more of a "this is the schematic I used, for this gainclone I just built."
I am looking for the "This schematic is good for...." information.
Same goes for chips... component combinations.... etc.
I certainly am not looking for handholding, nor am I looking to be handed a particular design that suits a particular application.
Misunderstandings... fundamentally (sorry, bad pun). 😀
I'm looking to learn.
geolemon said:
Fundamentals.
That's the most weired post I've seen so far in Chip Amps section.
I frankly don't know what you are looking for. Maybe you'll have better questions tomorrow?
You say you want to learn. But how you will learn without doing anything?
You should be reading not looking. Ask me a question and I'll tell you no lie.
That's backwards thinking.Peter Daniel said:You say you want to learn. But how you will learn without doing anything?
Which came first, the chicken, or the egg?
"You say you want to learn to race a car.
But how will you race a car, without racing a car?"
Learning to drive, might be a nice first step. 😉
And again, please save the assumptions.
Who said I didn't want to do anything?
If only ye knew me... 🙄
I'm looking for where to begin:
First, the information:
Fundamentals.
Concepts.
Boundaries.
Designs and limitations.
After all, there's a difference between
"I want to learn how to design an amp."
and
"I want to build an amp for some application."
I'm not looking to venture forth where no man has gone before...
I trust someone has been down these roads before.
I'm looking to learn from their findings.
I guess I'm surprised, because the schematics look so relatively simple, relatively few components...
...but no doubt many IC's inside that chip, masking the true complexity.
There's some balance, I'm sure, of the circuitry contained within the chip, and how the behavior changes at a macro level when you manipulate variables outside the chip.
Is this not documented anywhere?
So what do you want to do first to learn?
geolemon,
just start from one of the websites devoted to Gainclone. There are many of these, along the lines of "I finally built my Gainclone and here's how I did it". I recommend the Craig Fraser site, one of the true pioneers who kickstarted the gaincloning trend years ago:
http://home.ca.inter.net/~cfraser/Gainclonehome.htm
Craig's site contains commentary from Thorsten Loesch (aka Kuei Yang Wang) - the real thing!.
- Chip Amps
- Gainclone basics for an enthusiast who's new to them
