Just a recomendation on how this would work best and give me a linear volume control (linear sounding).
Most people recomend a linear Pot on the input, and then the center tap to be connected to the 10K resistor. Do I hook it up just like that? Or is there a different way that would work better for a log attenuator.
-Paul Hilgeman
-Paul Hilgeman
http://www.marchandelec.com/att.htm
It is similar to the AT24 on this site, ordered in 100K with a 'logrithmic' scale
Thanks for the quick replies,
Paul Hilgeman
Paul Hilgeman
Do I simply replace the 100K Linear Tapper found here:
volume
Ah!
The circuit you show needs a linear taper to get log control because the vol control is in the feedback circuit. The best move would be to return the log taper you have and buy a lin taper.
If that is not possible, you could just use the one you got and see if it works OK, chances are it is acceptable.
Else, I don't know any solution barring replacing the resistors on the controls.
Anybody else has some ideas?
Jan Didden
Ah!
Jan Didden
- Design & Build
- Parts
- Gainclome Volume Control using Log Stepped Attenuator
