How does the gain select on the schematic for this part work? Can I use a resistor, or is it something else? The schematic is in this pdf file on page 14:
http://focus.ti.com/lit/ds/symlink/tpa3001d1.pdf
from the datasheet it seems that Gain1 and Gain2 are TTL compatible logic inputs (5.5V max input voltage). You can change gain in 4 discrete steps as explained in Table1 on page 20. For low input level simply connect input to gnd, for high input level connect input to Vref (pin23).
Best regards,
Jaka Racman
Best regards,
Jaka Racman
