Gain in Aleph P 1.7
I have a question regarding Aleph P gain. In the position of 2K pot on the original schematics I want to put a resistor, so I can achieve max gain (22dB balanced/ 16 dB unbalanced). Which resistor value should I use? I will use Aleph P together with an Aleph 5. I will put stepped attenuator on the output. Thanks for advise!
Nelson,
My Aleph P 1.7 is coming along nicely also. It seems there has been a rash of Aleph P 1.7's being built lately. I would like to include a pair of Gain Controls on the front panel just like the genuine article. Can I use a linear taper pot? Would you recommend a high quality pot like an Alps? I have seen alot of press about conductive plastic pots. They are claimed to be very long lasting. Would that be suitable, not that it would get changed often?
I would try to use 6-step rotary switch of good guality with five 400 ohm registers--i.e. to get 0, 400, 800, 1.2K, 1.6K and 2K at each step. I approximate that these register values will give you 22dB, 14dB, 10dB, 7 dB, 5dB and 3dB gains. Or, you could use different register values.
Good luck.
Klaus:
If I put R49 into perspective, the gain is about 5 dB less than without it. That is, if my VR set to 150 ohms, then the gain:
without R49 is ~15dB
with R49 in the picture is ~10dB
In my current setting, I think without it is more correct when I test it with my ear... (but maybe I am wrong!)
Thomas
Hi, Klaus
Yes, we have R49. But at the same time we have R64, too, on the opposite side. I think that they have a +/- zero effect. Therefore, I did not consider them in my gain consideration.
Mr Pass might give me a strong punch to :zombie:.
jh6you said:
dB ~ 20 x log((R53xR56/(R53+R56))/(R51+R66+2K pot set value))
JH
I just asked again my colleague, my personal chief for any analog schematics…
He explained my that the story is a bit of more complicated. The P1.7 has two overlaid gain settings. One given, like described, by the parallel value of R53/56/49 + the input R of the power amp in relation to R51+poti+R66. BUT we also have a voltage feedback given by R48 to the input. Here the gain is also limited. So the total gain to be calculated with both – but I did not understand how…
I am stranded, I go and listen music over my P1.7, however its gain is controlled…
Klaus
