I am planning to build the BOSOZ. Accoring to Nelson Pass's instructions, a gain of 10dB and 1 to 2 volts output sounds the best for the balanced-in to balanced-out configuration.
Great, I understand that. I set P5 to 300 ohms and obtain a gain of 10dB.
Now, I plan on using the BOSOZ in an Unbalanced-in to Unbalanced-out manner. Now with P5 at 300 ohm, the gain drops to 3.5dB. I can get the 10dB back by lowering P5 to 80 ohms.
My question is: Does the BOSOZ in unbalanced mode also sound best with 10dB of gain and 1 to 2 volts output? And should I lower P5 to 80 to obtain this?
