(+)(G)(-) rails from a floating (+)(-) PS?
Just acquired a Lambda regulated power supply (from a local flea market) that has 5 lablled wiring terminals:
(+s) - sensing
(+DCV) - positive floating
(Case) - case
(-VDC) - negative floating
(-s) - sensing.
Note that as is I could only see voltage between (+VDC) and (-VDC)
but not between (+VDC)(Case) or (-VDC)(Case) due to floating.
It is quite easy to wire it as a single (+VDC)(G) or (-VDC)(G) supply by grounding the (-V<->Case) or (+V<->Case) accordingly.
Is there a way to get both +ve and -ve rails simultaneously?
Plan to use it for an amp project.
TIA.
If you design the power amplifiers carefully and make sure that the DC-offset on the output is really low and that the driver bias currents or other biasing currents does not flow into ground you can build a capacitive voltage splitter with a push pull emitter follower to make sure that the midpoint stays within +/-0,7V. Quad uses such a solution in one of their early amps and I have used it with success. The problem is that you end up with half the voltage swing i.e. if the converter delivers 60V you can only achieve +/-30V output swing.
If not a large amount of current needs to run through the
ground (i.e. a balanced output) then two resistors and a
cap (to ground) are sufficient to establish a virtual ground
that the circuit can reference. If the load runs to ground
so that the current is high, I suggest fairly low value resistors
and a really big cap 😉
Well, after poking around a bit the PS appears to be a variant of the discontinued LK351
model (Linear PS). It is adjustable from 0-40V (splitting would
be 0-20V rail), regulated to ~mV, and can source 18Amp at 40 deg. C. Weighs 95lb.
I was interested in its current capability and wanted to
try out a multi-channel amp (~8 for home theater) or a two
channel Aleph-X for music, which all seems to default to a +/-
rail configuration.
Would anyone see show stoppers trying to use this PS for
the above purposes?
Thanks for the responses and suggestions thus far.
