Greetings,
I have a Guitar Tube amplifier with an FX send-return loop. I would like
to create a passive (or active) volume control (attenuator) to insert it in that FX loop to control the volume of the amp (like master volume).
Should it be be line-level? (in general FX loops work at line level or is it irrelevant and is different from amp to amp?)
A 10K potentiometer should be fine or will I have problems with the impedances?
Any response will be appreciated.
Thanks in advance
Thanks in advance
