Funny smell
Hi there. After 30 minutes of projection a funny smell shows up in my room. It is quite similar to the smell in a solarium! (ozone?) 😕 Is it possible that it has something to do with the UV radiation? How to get rid of this smell? It is not very intense but after a while it gets annoying.
My setup: 400W BLV lamp (42000 lum)
400W sodium lamp ballast
eight_heads said:
what type of enclosure do you have your projector in? if it's mdf, ply, etc, the glues in the wood will burn and make a strange smell
Im using MDF / plywood
nick[x1] said:
Used any spray paint? as I used BBQ black matt spray paint, and it had to be 'burnt in' and then the smell went.
Nope, I didn't use any paint at all (this is still a prototype 😉)
...BUT i think I know where the problem is. This is my DIY lightbox:
The fan is sucking hot air from the lightbox through an alluminium hose. After a while the fan gets really hot. Maby not "burning hot" but hot enough to smell funny 😉, I think like 70 to 80 ^C. Now... do you have any ideas how to solve this problem? Should I look for a "temperature-proof" fan? Unfortunately there is not much space left for a longer hose 🙁
