Funniest snake oil theories
I have been thinking what you mean, and I believe you got what I was saying to Dan backwards.🙂
I don't see a frontwards or backwards here, on a highly subjective subject boths sides are right and don't care much about the other sides opinion. At some level tastes in audio sometimes get so eccentric that you have to step back and say to each his own.
I wish folks would stop applying the same openminedness and relativism to the basic foundations of physics. It's amusing that some of us get accused of being slaves to "book" learning when those they defend have no learning.
Yes, and copper dulls the sound unless it has been regularly polished. Let us draw a veil over all the copper used in the professional audio transformers and professional cables which the signal probably has passed through in the studio; just a metre of silver wire between the source and the amp restores the sound.
The sad thing is that JC has a physics degree yet he still persists in asserting nonsense. An interconnect simply needs a sufficiently good conductor (i.e. almost any metal, or a banana) surrounded by a sufficiently good insulator (i.e. almost any plastic, plus some air). If silver sounds brighter then this merely shows how widespread is mild synesthesia.
For not to mention all those electrolytics within the signal path of the mixing consoles' vast majority. But, surely, silver vs. copper wires in tonearms improve the sound, of course by eliminating the imperfectnesses induced by those doubtful components. So they say 🙄.
Best regards!
It's all made clear in Audio (bank) Note's website:
The Wires
The wire used to wind the transformer is also critical and in this area as in many others Audio Note™ was the company that pioneered the finest, Silver and it was therefore natural to put silver to good use in our best output transformers. Why silver sounds so superior is still not fully understood, but it is unlikely to be simply a function of conductivity.
One theory puts forward the notion that the intense AC electrical and magnetic fields within the transformer interact in some way with the wire material. Another theory considers the crystalline structure of each material copper is very sensitive to impurities, in particular oxygen, it is also possible that the differences are caused by effects that occur on the surface of the material. Surface chemistry is different to that of the bulk material, the atoms at the surface are exposed, rather than being enclosed within the crystal lattice. When the metal is drawn into wire the surface will quickly adsorb components of the air, particularly oxygen and nitrogen as they are most prevalent and despite our best efforts (we coat our immediately it leaves the die), some contamination still takes place. After a while a bulk reaction takes place producing a layer of oxide and sulphide. Silver and copper compounds are similar chemically but not identical. Copper oxide is a rather poor semiconductor compound capable of producing rectification effects whereas silver oxide is a good conductor and is used in switch contacts and batteries. It may be possible to draw wire in an inert atmosphere such as argon and then cover the wire before it reaches the air or to chemically treat the surface before coating to further improve the wires.
Maybe good be careful about distinguishing between attempts at colorful or descriptive language, use of analogies, and synesthesia. The latter is an actual blended mental experience, such as when printed black and white numbers appear in color. The mental experience is exactly the same as if they were printed in colored ink.
On the other hand, sometimes people use words to try to describe sounds for which no preexisting words have been defined. In that case, it may be nothing more than colorful descriptive language.
Or, words may be chosen in an attempt to describe how something sounds using an analogy another person might find helpful.
For example, sometimes digital sound has been described as "grainy." I never understood why, but I kept trying to figure out what was meant by the term. Finally, I did hear some digital that had a rough, coarse, sort of sound at HF. Grainy wasn't a too bad a word to describe it, but I never mentally experienced grain and music blended somehow together. In fact, I don't think I have ever had a mental sensory experience called grain. I don't even know what it would be like. Maybe the closest would be rubbing some seeds of literal grain between my fingers, which maybe feels a little coarse and granular, but when I heard grainy music, my fingers and everything felt compelety normal. No synesthesia there. None.
Silver is used in high frequency equipment, isn't it? I have some big Siemens tubes with sockets that were ripped out of some medical equipment. Leads have been cut. Some of these leads soldered on to the socket are silver foil. Also suppliers of HF litz (e.g. Elektrisola) list silver as a standard conductor. What is that stuff used for? I could imagine winding inductors where the thick insulation and lower DCR gives a higher Q. I'm at a loss what's going on with the tube socket.
Silver plating protects copper from tarnishing. I can't see any other advantages. In transformers it's enamelled anyway so no point. For Audio Note it's just marketing since they admit to not knowing what advantage is it does have. They say it's probably not about conductivity, then later go on to talk about the conductivity of silver oxide
It is a little convenient - that the more precious metal sounds better. Good for margins. If it had been aluminum wire that sounded better would it have been used at all?
It is a fact that silver and copper are atomically quite different and Audio Note suspects their oxide properties matter and are different. So it is not absurd to entertain the idea that silver wiring sounds different to copper. I haven't listened to silver wire so I can't say.
I think the interfaces between different metals is an important area, particularly what materials are used to join them and the quality of those joins. The composition of the solder used could matter.
Suspicion or FUD. FUD is the key to snake oil sales!
Is is pretty absurd, the method of conduction is the same and the difference in conduction is around 7%.
Yes materials do matter, at least once you get into the GHz region. Gold plate traditionally used a nickel flash on the base brass. Nickel contains iron which causes IMD at high frequency. At audio levels it's FUD. Worried about it then buy a pair of KEF LS50 wireless speakers.
