Funniest snake oil theories
And there are plenty of people who will strongly disagree with that.
There may be. The current state of knowledge means they would be mistaken.
If some scientists select a sample of motor vehicles for sale, and test their capabilities, do we now know what any vehicle is, or is not, capable of?
Irrelevant. Not eve nsure what point you are trying ot make here.
How about, we run that A/D and/or D/A process through on some sample, copy of a copy style, 3 times, 5 times, 10 times, 100 times - when do we get to the point that the deafest person on the planet can pick the difference? The thing being, there will always be degradation, so then we are playing a sensitivity game, who can pick it up ...
Why on earth would you do that? Of course the sample needs to be first generation - and there is no sane reason for it not to be. And if it IS 1st Gen at a reasonable resolution the research (not handwaving) tells us we can expect it to be so close to the original that it is unable to be separated in a listening test.
Most people who fiddle with audio, that is of decent quality, to any degree know that doing anything, almost anything, changes the sound - it's just accepted that that is the way of it. The amplifier, and digital source threads here on this forum are riddled with subjective assessments that altering something altered the sound - are they all deluding themselves?
Not all, but a lot, yes.
Methinks the shoe is on the other foot - it's up to whoever to prove that the a/d and d/a makes no difference. Or do you just assume that a piece of test equipment is always right, just because it has the name of an established manufacturer on it?
This really does say a lot about your views and I'm afraid a very stupid thing to say, you propose just blindly believing anything anyone sais without any proof🙄
That having tested some a/d and d/a chains that the performance of a particular, untested unit can be predicted.
The repetition exaggerates the degradation, so its characteristics can be easily perceived - the problem is that the degradation may be of exactly the sort that you're trying to 'measure' in the equipment being modified - how does a listener sensitive to that characteristic differentiate the two, overlapping behaviours?
If you are referring to the point about the reliability of equipment, I'm saying that blind faith in a measurement simply because you respect the name on the front panel is misplaced. Any piece of equipment can be faulty at some point, or there may be a major mistake in the procedure of how the measurement was taken.
A series of physics lectures at uni has stuck strongly in my mind throughout these years, and it was about the methodology of measuring. It was based on an experiment to measure black body radiation in some aspect, to an accuracy greater than was currently available - the setting up of the experimental apparatus was 1% of the effort required, and the other 99% was needed to work out compensations, corrections for all the factors that could cause significant errors in the number that was read off.
Sometimes I think the 'magic' of getting a number is so satisfying that the reliability of the figure is not really thought about enough ... 😉
It really is getting silly, haven't you heard of calibration. You realty need to look at how things are made and designed, and how world standards and calibration play a part so we work with the same baseline!
This all stemmed from a point about whether adding something extra into a circuit makes a difference or not. Common sense tells me that it is more likely to make a difference, then not make a difference, so the onus should be on the proving that it doesn't make a difference.
Sorry if this doesn't sound like intelligent engineering ...
This was the point of my post last night. Most people seem to get so distracted by this beautiful number that they just completely forget the context in which it was taken and just assume that it paints the whole picture.
"Component a has .01% THD according to this test therefore any contribution to the reproduction of audio is completely undetectable to human ears. Case closed." Meanwhile they are completely ignoring any number of conditions that could cause the device to not perform in the way that it did during this test.
Again, I am not saying these unpleasantries can't be measured. Just that they are not covered by this single measurement that was taken in some other place, under specific conditions, to which they refer to claim the near perfection of the device in question.
I keep hearing about these people, and for whatever reason, never seemed to have met one. Can you give me a specific example?
Then you must be purposely trying to not see it. It happens daily in countless threads.
Just look for this type of post:
"Amplifier in question has .01% THD. If you like another amplifier better than this one, you are either fooling yourself or you like distortion (AKA "coloration")."
Points like this are made daily. If you don't see it, it's because you don't want to, and I am not going to dig around the forum to prove something that you want to close your eyes to.
I give up.
They are away with the Bybees.
And so we don't get further mixed up, my comment is a play on the phrase "away with the fairies"
One last question, to those that seem to be against measurements, how can you design anything without measurement's and metrics to quantify your design, human hearing does not apply as a repeatable measurement whatever you think, though listening tests can be correlated to give some metrics under stable and controlled test conditions with a wide enough sample of participants, but those never materialise here only sighted listening.
In terms of designing the majority of the circuitry of course metrics, in one form or another, are essential - however, there is frequently that niggling, known unknown 🙂, which forms part of the picture, and determines whether the end product succeeds in producing subjectively pleasing sound. Absolutely authorative listening tests would be terribly cumbersome, and a nightmare to monitor for complete confidence in the results - so the reality is that shortcuts are always taken ... and no-one is happy with where we're at ...
I completely understand this, and all the ways our consciousness gets in the way, but....
Why is it widely accepted in food and chemistry that human taste and smell are better than any machines we have made, and people take professional tasters and sniffers conclusions as fact? I'm sure their personal bias gets in the way just as much as it does for audio.
For food chemists, the goal is NOT reproduction of an original, but instead something that's pleasing to the consumer. In audio, the goal is reproduction of a previous performance.
In food, tasting is done blind. The tasters don't know which of the options have what differences in them. Why isn't this done in audio? Because you're afraid of the results?
done all the time matey ....
Actually, I don't think an exorbitant price is useable as proof of effectiveness.
jn
It is when it's paid after using the product for 30 days..... 🙂
