3" this sounds like a veiled reference to our favourite component for verbal self flagellation.
Sound bars create quite a surprising souroundsound, often much better than multiple speaker set-ups in UK small living rooms, would rather listen to a soundbar than the 5 speaker set up where the speakers are just way out of position.
Tired of clutter, made my pair of dual concentric series 600 tannoys and a nearly matching d6c into a three channel sound bar; along with a isobaric 10" pair of subdrivers , forms a good tv stand, saves a lot of space.
It sounds more natural than too wide too high mounting, and allows for very solid sealed cabinetry.
Couldn't part with old tannoys, they are excellent cinema speakers.
On equipment that I install it utilises chokes on the ground similar to what you explained. The purpose is to arrest transients generated from high current contactors when the coil is energized or de energized. The transients cause the digital control boards to reset. Placing the chokes eliminates this. The machinery has passed UL standards with the chokes in place. Think the value is 4 mH.
Be careful of the distinction between UL listed and UL standards. We just received a lessons learned memo from the gov talking about this distinction. Apparently passing UL standards is not the same as UL listed. We are required to use listed equipment, and somebody was gigged for selling equip which didn't have that tag on it, yet the product sheet stated "to UL standards".
I was referring to NEC 2008Anyway, my point is that the machined is manufactured in Germany and connected in the US. UL standards govern this, not NEC. NEC is for building codes and what is installed in buildings for safety, not machinery or appliances.
(I have bolded what I believe to be the relevant part.)
250.4 General requirements for grounding and bonding.
250.4 (A)(3) Bonding of electrical equipment.
Normally non current-carrying conductive materials enclosing electrical conductors or equipment, or forming part of such equipment, shall be connected together and to the electrical supply source in a manner that establishes an effective ground-fault current path.
250.4(A)(5)Effective ground fault current path.
Electrical equipment and wiring and other electrically conductive material likely to become energized shall be installed in a manner that creates a low-impedance circuit facilitating the operation of the overcurrent device or ground detector for high impedance grounded systems. It shall be capable of safely carrying the maximum ground-fault current likely to be imposed on it from any point on the wiring system where a ground fault may occur to the electrical supply source. The earth shall not be considered as an effective ground-fault current path.
jn
I didn't even know the distinction existed..And to think that I used to work at UL, and I find the distinction trivial. '-)
Here's the scoop sent to us.
Discussion of Activities:
In October 2013, Savannah River Site (SRS) ordered a part off a manufacturer’s cut sheet which
referenced a UL Standard. The particular application required the part to be UL Listed and the
reference to the UL Standard was thought to mean that the part was UL Listed.
Analysis:
When the part was received, there was no UL stamp or UL marking of any kind. The manufacturer was
contacted and responded that, just because a UL Standard was referenced on the cut sheet, it did not
mean the part was UL Listed.
It meant that the part was manufactured to the requirements of the UL Standard but it was not
independently certified by UL. According to the manufacturer, if the part had been certified by UL, the
catalog would have explicitly stated that the part was UL Listed and it would have been appropriately
marked.
In discussions with UL tech support, they confirmed this practice. They said that many manufacturers
purchase UL Standards and produce parts built to the standard; however, they do not pay UL to
independently certify the part (which is what would have been required for the part to become "UL
Listed").
Recommended Actions:
When purchasing parts that are required/desired to be UL Listed, we need to ensure the catalog or
other vendor documentation explicitly states that the part is UL Listed.
If there is any doubt or the documentation is unclear as to the UL pedigree, contact the manufacturer
and confirm the part is UL Listed prior to ordering.
jn
The difference is when you get hauled into court with a product at fault, you can say either (1) the safety agency certified that we meet the requirements, or (2) we designed to meet the sSafety Agency specifications.
(1) is a more defensable position.
Only John Cleese has you beat, so many words, so little said.I would like to make a point of view here. I essentially agree with 42. He is defending the experience of numerous audiophiles and many successful manufacturers. I'm not talking about big money makers like Bose, HK or Dolby, who actually have a cynical undertone in their philosophy, but successful audio designs like the early vacuum tube Marantz, some JBL speakers, etc. These are 'keepers' because they were designed and built with everything that the designers knew as to what may or does make a successful audio product. You will often find that when we make the product of the decade or some such, that we throw years of experience of both ourselves and every other successful designer that we can learn from, use the best passive and active devices that we can buy, and build each device with TLC or tender loving care, often to the point where we eventually go broke, because we just cannot charge enough for our efforts. This happened to Saul Marantz (when he owned Marantz), me with Vendetta Research, and a number of other manufacturers. It is a 'labor of love' rather than gross profit, and we pay the price, BUT it is worth it, IF you want to be respected over the vast majority of manufacturers making a similar device, such as a preamp, power amp, tuner, etc.
The key to success of this type is to throw everything at the design, seriously attempting to leave nothing out. Perhaps, some things could be left out, but which things? That is the dilemma.
The key is if you are making an amp, you dont need to throw in a can of baked beans just in case the akakp needs one.
I try to design all my amps to meet the appropriate safety specs even though I don't sell them. I value my children who I give the amps to.
That said, I have not replaced my stock of MOVs with UL 1449 (Sept 2009)approved devices.
Jack Bybees Baked Beans.You make me laugh, peteleoni. Why not give us an example?
for example sat tv signal (xy ghz) is polarized-its spin. to save the bandwith. why it does not exist on lower frequencies?🙂Why! Why not and what is wrong, if its directional it will be directional at all frequencies, and some of us are interested into the low GHz for digital, what is wrong?
I presume you have a PC...Work out the harmonics on DDR3 running full pelt.
Anyway any documentation on directivity of copper, carrying signals? I would presume the same mechanisms work on all types of conductors, and any view on whether silver is directional?
not sure why to do rocket science on speaker cables.
super high frequencies -the amps will not amplify it, tweeters will not play it, average age ears will not catch it
If our society gets any *safer* we will wind up brokering all the extra years of life we are cheating death out of back in some form or other. We should always remember that safe has a cost. Really this is already occuring, we just dont speak of it.I try to design all my amps to meet the appropriate safety specs even though I don't sell them. I value my children who I give the amps to.
I found a leaked video of the Bybee Company discussing their current products.
Blazing Saddles 1974 Campfire Scene - YouTube
Less measurable distortion, class a as far as possible, big efficient speakers to keep it all there.
Pete- big speakers? Is this to mean big drivers too?
I'm guessing the reasoning is a larger radiating surface produces more volume with lower excursion, meaning lower Doppler distortion.
This may be why I always liked my Dads old voice of the theatre speakers from when the Stardust Theatre got torn down.
We never worried about dispersion, beaming, or prat 35 or 40 years ago.
I must admit, the original Voice of the Theatre speaker my father had sounded pretty good, as long as the cat hadn't unplugged the DC power supply for the magnet. Not very deep bass, nor really good top end, but it did fill the room....
The later Magneplanars were better, though....
Great comment, I'm concerned about the collateral damage issue we cheat the reaper at the expense of less "enlightened" folks.
Of course, that is the big bugbear - that our society is very 'unfair' in the way it operates in so many areas - aspects of "primitive" cultures living in South American jungles are so far ahead of us in this respect ...
Darwinism.
jn
- Member Areas
- The Lounge
- Funniest snake oil theories
