Funniest snake oil theories
However, they'll show a nearly constant voltage drop, easily measured. And if the guy selling them claims that they violate the Second Law, he's a fraud.
My scientific integrity and intellectual honesty can't be bought for a couple of expensive lunches and a car ride. YMMV.
Why doesn't Quantum Purifiers have a double male connector to run directly from Pre to Amp? One could selectively raise up one component or the other with those "magic wood balls"...to match-up??
Best of both..........Magic Worlds.
_________________________________________________Rick..........
Mr. Curl openly supports Bybee devices. Such info is invaluable to anyone who needs to choose an amplifier among a lot of good designs. Look at this the blessing that it is. All of us are not ee's we have a point of reference that may be useful which ever side you take. There may be those who would actually choose an amp based on this "vision" I appreciate the window inside the designer.
Or another tack:
"Hi my name is *.* and I was taken in by snake oil"
"Hi *.*"
Then go the 12, repent and design the least expensive, most reliable, best looking, lightest weight, and cleanest hi power multi channel amp in its class!!! (With analog volume/remote) Go!
....Hero time parades, tears, kumbaya, joy!
This is most probably the equation for the resistance in a newer Bybee device: R= h/2e(squared) or 12.9K ohm, with a lot of these in parallel to make .025 ohms. Think about it.
Here is the approximate equation for a diode: R=V(t)/I or 26mV/I or kT/Iq which is different than the above equation. This is why a diode changes its dynamic resistance with current, AND the Bybee device does not.
You've explained nothing. And ended the gobbledygoop with "that's why their different".
Try again.
edit: Why is it I am reminded of Lily Tomlin?.."and that's the truth..phhttt!!"
jn
Peteleoni, I strongly approve of you finding the best real bargain in power amps. Go for it!
Sure looks like your Parasound are strongly in the running.
So drop the bybee crap, say it was your evil twin. purge, confess, cleanse, all that crap, take a load off Annie, twist your head around 360 and cuss disgustingly, whatever it takes, insence, say ahmmmmmmmm, fung your shui, get a rug that points east, an enema, whatever....
