Fullwave rectification using two 6w4gt tubes.
Hello, i'm new to all this. I am building a valve amp that is split into 4 chassis. Left and right with power supply and signal seperated. I will be using 6J5 as the input and 6V6GT as the output. I wanted the power section to look the same as the signal section, so have opted to use 2x 6W4GT damper diodes to rectify my supply. My power transformer is a Hammond 370KZ, 275v-0-275v wth a 6.3vct 6amp filament supply. I can't find much info on how to safely supply the heater voltage to the 6W4GTs. Please can anybody advise me?
