Hi !
I've just completed (?) my first venture into DIYing a set of speakers. I've used 8" Audio Nirvanas in 18L enclosures made from 19mm mdf lined in the insides with bitumen and damped using some kind of sonically correct speaker wool. Wiring is done using Supra Ply 3.6 and the bassreflex is placed as a slot on the front. These speakers have no real low end but they sound exceptionally clear and welldefined. BUT! As soon as there is no sound they hiss very "loud". This is annoying! Have I done anything wrong ? Or is this a characteristic of the fullrange speaker ?
The rest of the setup: Tripath amp (Audio Digit) and Rega Planet 2000 cd player with Rega Couple interconnect and Supra speaker cables.
Any advice is welcome !
/Mirland
/Mirland
Speakers are like computers: they do as they are instructed. You are likely hearing noise or some other auditory "junk" from the signal path. Try changing preamplifiers, sources, amplifiers and see what happens. Worst case, change the power circuit (and / or location) in the house.
If you're worried about picking up RFI, grab some ferrite clamps and stick them on all signal and speaker leads. Alternatively, wrap them in aluminium kitchen foil. I kid thee not. It's not as good as a well engineered shield, but it's very cheap, and if RFI is a problem, it's better than nothing until you can change leads or get the clamps.
My money is that it's your amp that's causing the problem; easiest way to find out is to swap it out for one borrowed froma friend if you haven't got another one lurking around the house somewhere.
Best
Scott
Best
Scott
I am also comig to the conclusion that it might be the amplifier. I don't know which is worse 🙁
/Mirland
/Mirland
My guesses would be that the hiss is caused by the source or amp or having AC power cables or power sources near the speaker wire. If the speakers have a BSC, the problem could also be the passive components.
I just got home and tried out a few things:
1. Changed amplifier: First an Onix OA21s - same level of hiss. Then a Naim Nait 1: Same level once again.
2. Changed speakers using my tripath amp: Hiss at a much lower level.
I am really confused. I would like to think it might be the tripath but I don't think so. My setup should be rather well organized BUT I am missing a dedicated ground spur.
Could it be that the speaker is actually too effecient ? That it multiplies the potential hiss from the amplifier/s ?
/Mirland
/Mirland
Which amp exactly?
I hope this link works:
http://www.autocostruire.com/catalo...d=258&osCsid=a59d3e7ec8ecf83b07f73d47f02e88bb
I have constructed a nice steel casing and am using this psu:
http://www.autocostruire.com/catalog/product_info.php?products_id=260
However my version is the 5A.
/Mirland
/Mirland
Well there is (was?) a known hiss problem with the Fernice amplifier from Autocostruire but not with the version in that link as far as I know (at least the one I have has no hiss).
But the problem is more likely to be with the amp than the speakers so I would contact the supplier and ask if they can suggest anything. 😉 (Or ask on the Class-D forum)
Nuuk said:But the problem is more likely to be with the amp than the speakers...
But it could be the source...
The problem is most certainly with your preamp or your amplifier.
Loudspeakers cannot reproduce "hiss" when none is present within your amplifying system.
I would say you should check out the wires as well. I know others have mentioned this, but try moving things around a bit while you hear the hiss. Try moving wires or moving components around. Could possibly be a loose connection, but that would most likely buzz. I doulbt it's the speakers.
One other thought is that it could be from something else on the same electrical circuit. Good luck with it.
As I still don't quite know what to do I've also started a thread in the class-d section.
But I've connected the t-amp to another set of speakers (traditional two-way stuff) and there is no more hiss than when I'm using my other amps...
Argh...
/Mirland
Argh...
/Mirland
Ok, I am gonna go out an a limb and bet it's the source. I say this simply because he already switched amps around and still had the problem.
We know it's not the speakers, BUT they could be a bit of a "culprit" here I think. Not havig played with the Audio Nirvana speaks I cannot say for sure but they appear to be like Fostex "sound-alikes" which means they may tend to have a bit of a forward mids and highs ("hiss" frequencies). This forwardness, may be just magnifying the "lesser" hiss you hear in your other speakers.
To recap, he has switched amps and speakers out, eliminating these as the source of the problem, what's left? Source or preamp...no?
Noidster
Noidster
- Full Range
- Fullrange hiss ?
