Looking to do a full range BLH with the Fostex FE166ES-R Special Edition. The SPL is 95.5 dB/W/m. My set-up is a c-j PV10A and the sonographe SA-250(2x125). For speaker cable I have an 12 meter run of DIY plenum cat 5, 16 twisted pairs for a 12awg. The cat 5 is low inductance, low resistance, and high capitance. The 12 meter pair is necessary for the WAF. Will my current electronics and speaker cable be OK with the Fostex FE166ES-R Special Edition back loaded horn? Is the amp too many potential watts for the driver?Thanks
AllCaster said:Is the amp too many potential watts for the driver?Thanks
Only if you punish the driver with amps power . You should be fine. Just be careful.
