from a thrift store -
81115
digital film -
at a 'subway' (store) -
81115
digital film -
western electric 750a
755survey.htm
81,840
755survey.htm
81,840
82,122
470 calories, for (only) 25 cents -
Leak 8x13 -
There used to be a debate about the Radio Shack 40-1197 is it realy a
fostex fe103 well I do have one that is.
well considering how many raw drivers RS sold over the decades with the 1197 designation, and the number of production and labeling changes by Foster (OEM) and Fostex , it could be a moot point as to which is the "official" FE103 😉
i.e. there isn't "one", just the one(s) you have on hand?
83178
Technische Daten (Herstellerangaben):
Modell: 326255
107 mm Breitbandlautsprecher
80-18000 Hz Übertragungsbereich
89 dB Kennschalldruck
15 mm Schwingspule
2,7 gr bewegte Masse
Konusmembran aus Papier
plastizierte Stoffsicke
Stahlblechkorb
Ferritmagnet, 78x20 mm
Abmessungen aussen:105x105 mm
Ausschnitt: 100 mm
Einbautiefe: 45 mm
Gewicht: ca.550 gr/Stück
Thiele-Small Parameter (Herstellerangaben)
Nennimpedanz/Gleichstromwiderstand: 8 / 7 Ohm
Resonanzfrequenz: 80 Hz
Gütefaktoren(Qms/Qes/Qts): 2,17 / 0,38 / 0,33
Äquivalenzvolumen(Vas): 6,9 Liter
Effektive Membranfläche(Sd): 50 cm²
Antriebsfaktor(BL): Tm
Schwingspulenüberhang (Xmax): 0,35 mm
from here -
1 Paar Fostex FE-103 HighEnd Breitbandlautsprecher, TOP bei eBay.de: Sonstige (endet 13.03.10 11:03:45 MEZ)
83,960
84,265
- Full Range
- full range pics-
