Yes,
I should even add that If the area below 200hz is covered by other speaker then the size of the faital 4fe35 is not important. I guess you can even use them in infenit baffle
eh, i'd say a woofer, but some say subs can go to 200hz...………….
I'm not a very big expert but I don't see the problem with her to have 200hz with an interface (DSP) or correct me.
What do you mean? the image is very small...
I am not an expert either. I have the same drivers and I tthink the choise we made with the Faitals is very good for midrange or mid high.
Personally I always prefer original sound so I never use a DSP. Are you looking for woofer to cover lower frequencies.
No I do not plan to buy a woofer, my main speakers are already mounted 90%
I'll continue with my sub and my DSP to try to swung and integrated the whole thing.
The same for my center, otherwise I will change my designated one.
- Full Range
- Full Range Faital for center
