Full-Range enclosures inside subwoofer enclosure
Hello,
Could anyone tell me if adding 4 full-range enclosures inside the subwoofer enclosure will cause any issues with bass?
The 4 enclosures have a passive radiator on the left side (or right for the 2 right full-range enclosures)
The subwoofer has about 130 liters of space once you subtrack the other enclosures. Box is tuned to 28 Hz. Subwoofer also has a crossover and is connected in reverse polarity to fix phase issues with other drivers (picture below)
The 4 full-range enclosures are slightly above 2 liters (each).
If you need extra messurements here are a few 3d model files (all the same model), should work with any 3d software (needs to be unzipped).
Speaker.zip - Google Drive
Drivers:
1.) Visaton WS 20 E /4 Ohm - WS 20 E - 4 Ohm | Visaton
2.)4x Visaton FR10 HM/8Ohm(2 pairs wired in parallel) - FR 10 HM - 8 Ohm | Visaton
Boxsim simulation File under attachments (change the file extentsion to ".BPJ").
Images:
The holes on the side panels are for passive radiators, should i use closed boxes anyway or are passive radiators fine?
I'd skip them- the extra complexity doesn't seem to add much of anything, to my perspective, and I'd rather a small sealed enclosure at the expense of 40hz higher XO (or whatever it is), with the attendant improvement in power handling. The high-pass filter on the small drivers will be critical to keeping this capable from an output standpoint.
