full range design for galaxy 5"
I had been interested in this little guy as well, but it kinda fizzled after I saw the Dayton PA-130 beating it (on paper only) for less money. The best I could whip up back then for this driver is 6 or 7 liters tuned at 125 to 140Hz. Or 4.5" x 7.5" x 11" (internal) with a 1.75" hole (assuming 0.75" material). There's no x-max spec on the PE page, which could mean two things IMO. Either the x-max is so low, like in the 0.5mm or even 0mm range, that the manufacturer or PE just leaves it out. Or the x-max may be reasonably low, like 1mm, and the manufacturer doesn't want know-nothings skipping over this driver as soon as seeing that. Either way, assume that it is quite low, and you're gonna need to highpass aggressively at 150Hz or a more low-parts-count XO nearer 300Hz. Even a 2 liter sealed box can't save you from posible over-excursion here. Were it me, OB highpassed at 500Hz and biamped. Kinda an odd duck.
